Show 2 replies
1. Re: Nested sequence duration changed problem
Harm Millaard Mar 19, 2010 1:28 PM (in response to soom1976)First update to 4.2.1
Then edit in the original sequences only. Changes will be reflected in the nested ones.
2. Re: Nested sequence duration changed problem
soom1976 Mar 21, 2010 2:25 PM (in response to Harm Millaard)Harm Millaard wrote:
Updated to 4.2.1
Nothing changed
It still remembers the duration of the sequence at the moment, when it was nested. If I edit the nested sequence and prolong it's duration, I cannot extend this sequence on the main time-line. I still can shorten it, but not to extend it. If I want to make the nested sequence longer, what I do is nest everything inside it again, then copy paste it to the original time-line – this is a bit awkward...
