1. Re: Can't find ProPhoto RGB in drop down list in Color Settings
John Joslin Mar 20, 2010 9:33 AM (in response to Matthew A Kraus)Well it appears in the drop-down list in my
Settings dialog using Vista 64.
Have you updated CS4 to version 11.0.1?
You could also try resetting your preferences as described in the FAQ.
http://forums.adobe.com/thread/375776?tstart=0
You either have to physically delete (or rename) the preference files or, if using the Alt, Ctrl, and Shift method, be sure that you get a confirmation dialog.
This resets all settings in Photoshop to factory defaults.
A complete uninstall/re-install will not affect the preferences and a corrupt file there may be causing the problem.
2. Re: Can't find ProPhoto RGB in drop down list in Color Settings
Matthew A Kraus Mar 20, 2010 9:53 AM (in response to John Joslin)Thanks for the reply. I am using version 11.0.
I tried resetting the preferences and unfortunately, that didn't solve it. Any other ideas? Thanks again.
Matthew Kraus
3. Re: Can't find ProPhoto RGB in drop down list in Color Settings
John Joslin Mar 20, 2010 10:00 AM (in response to Matthew A Kraus)Matthew A Kraus wrote:
Well you need to update to 11.0.1 like I said!
See: http://www.adobe.com/support/downloads/detail.jsp?ftpID=4292
4. Re: Can't find ProPhoto RGB in drop down list in Color Settings
Matthew A Kraus Mar 20, 2010 10:03 AM (in response to John Joslin)Sorry, my last reply was a typo. I am using version 11.0.1
Matthew Kraus
5. Re: Can't find ProPhoto RGB in drop down list in Color Settings
D Fosse-QDEaQ1 Mar 20, 2010 11:01 AM (in response to Matthew A Kraus)Check in Program Files (x86) > Common Files > Adobe > Color > Profiles. Icc profiles are only installed in the (x86) directory.
The list you mentioned are the profiles in the "recommended" subfolder, if it's outside that folder it will appear further down in the working space options.
It should also be in Windows > SysWOW64/system32 > spool > drivers > color.
If for some weird reason it's missing altogether you can download it. Do a google.
6. Re: Can't find ProPhoto RGB in drop down list in Color Settings
Matthew A Kraus Mar 20, 2010 11:38 AM (in response to D Fosse-QDEaQ1)Right you are. I found it further down the list. THANKS.
Matthew Kraus
