3 Replies Latest reply on Mar 21, 2010 5:04 PM by Flex harUI
    Problem with "new Group()" performance
    Mariusz Dalewski
      Hello
      I need to create many spark.components.Group objects (more than 10000) and have some performance problem. In many cases new object was created in 0-5 ms, but sometimes in 266-700 ms.
      This is output from my test app (code below):
      [Time] - [Count]
      0 - 91035
      1 - 7308
      2 - 393
      3 - 365
      4 - 408
      5 - 404
      6 - 66
      7 - 3
      8 - 3
      9 - 2
      10 - 1
      12 - 1
      13 - 1
      16 - 1
      19 - 1
      24 - 1
      39 - 1
      63 - 1
      67 - 1
      210 - 1
      260 - 1
      266 - 1
      690 - 1
      And code:
      <?xml version="1.0" encoding="utf-8"?>
      <s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
      xmlns:s="library://ns.adobe.com/flex/spark"
      xmlns:mx="library://ns.adobe.com/flex/halo" minWidth="1024" minHeight="768" applicationComplete="windowedapplication1_applicationCompleteHandler(event)">
          <fx:Script>
          <![CDATA[
              import mx.events.FlexEvent;
              import spark.components.Group;
              private var container:Array = new Array();
              protected function windowedapplication1_applicationCompleteHandler(event:FlexEvent):void {
                  var map:Object = new Object();
                  var i:int, start:int, stop:int;
                  var grp:Group;
                  for(i = 0; i != 100000; i++) {
                      start = new Date().getTime();
                      grp = new Group();
                      stop = new Date().getTime();
                      if (!map.hasOwnProperty(stop - start)) {
                          map[stop - start] = 0;
                      map[stop - start]++;
                      container.push(grp);
                  for (var key:* in map) {
                      trace(key + " - " + map[key]);
          </fx:Script>
      </s:Application>
      Can you test this code in yours computers?
      Anybody know where is a problem? I don't have any applications run in background. etc...
      Testes on SDK: 4.0 (default in Flash Builder 4 b 2), 4.0 build 13875, 4.1 build 14741
      Mariusz Dalewski
        • 1. Re: Problem with "new Group()" performance
          -BoNzO- Helper
          That's what I get :
          0 - 99108
          641 - 1
          578 - 1
          422 - 1
          31 - 2
          328 - 1
          15 - 328
          16 - 554
          594 - 1
          500 - 1
          282 - 1
          703 - 1
          My laptop is maybe a bit faster.
          This has nothing to do with group ! I'm guessing the flash virtual machine has to perform some memory management in between or some other operations.
          Look at the result when using a vector of groups instead :
          0 - 89985
          1 - 7899
          2 - 412
          3 - 385
          4 - 422
          5 - 655
          6 - 204
          7 - 7
          8 - 6
          9 - 5
          10 - 3
          11 - 4
          12 - 1
          13 - 1
          14 - 3
          17 - 1
          37 - 1
          19 - 2
          22 - 1
          23 - 1
          34 - 1
          30 - 1
          Side note, more than 10.000 groups ??? Are you sure you can't use something more lightweight ? ( Sprite, UIComponent, etc ) A group is a container with many, many functionalities and it comes a cost.
          • 2. Re: Problem with "new Group()" performance
            Shongrunden Rockstar
            Here are my results with a few classes:
            spark.components.Group:
            0 - 87676
            1 - 10563
            2 - 340
            3 - 346
            4 - 349
            5 - 480
            6 - 222
            7 - 6
            8 - 4
            9 - 1
            10 - 1
            11 - 1
            76 - 1
            13 - 1
            14 - 2
            16 - 1
            12 - 1
            407 - 1
            472 - 1
            26 - 1
            94 - 1
            31 - 1
            mx.containers.Canvas:
            0 - 79601
            1 - 18534
            2 - 287
            3 - 258
            4 - 284
            5 - 383
            6 - 328
            7 - 243
            8 - 42
            9 - 11
            130 - 1
            11 - 2
            324 - 1
            13 - 2
            14 - 3
            10 - 3
            18 - 1
            12 - 9
            21 - 1
            741 - 1
            504 - 1
            27 - 2
            28 - 1
            351 - 1
            mx.core.UIComponent:
            0 - 89460
            1 - 8748
            2 - 337
            3 - 382
            4 - 317
            5 - 527
            6 - 209
            7 - 3
            8 - 2
            9 - 3
            42 - 1
            99 - 1
            12 - 1
            462 - 1
            14 - 2
            15 - 1
            116 - 1
            118 - 1
            124 - 1
            30 - 1
            31 - 1
            Sprite:
            0 - 98957
            1 - 1030
            2 - 1
            5 - 11
            6 - 1
            spark.primitives.Rect:
            0 - 99598
            1 - 402
            spark.primitives.supportClasses.GraphicElement:
            0 - 99598
            1 - 402
            As Bonzo mentioned this doesn't seem to be a Group problem as Canvas also has some long times.  UIComponent is lighter than both Canvas and Group and it still has  a couple entries longer than a few ms.  Notice that using Sprite or GraphicElement is much faster.  GraphicElement is very lightweight, are you able to use it instead of a Group? 100,000 Groups seems like a lot, can you explain your use case, maybe there is a way to use virtual layout to minimize the number needed at any one time?
            I think the container.push() call might be causing a lot of the delay, if you use:
            private var container:Array = new Array(100000);
            container[i] = grp;
            You should see less large delay times.  It might be good to try using a Vector instead of an Array like Bonzo suggested too.
            • 3. Re: Problem with "new Group()" performance
              Flex harUI Mythic
              The operating system is stealing cycles for various things and delaying your
              code.  Flash may execute actionscript in a single thread, but that thread is
              constantly stopped in order to give other programs on your computer time to
              run.
