quote:
Originally posted by: Colum McAndrew
If Leon's advice doesn't work, is it possible to edit the entire topic in DW and then import into RH? As Leon says, RH is trying to save you but you may be able to save it the bother by not using it. Just a thought
quote:
Originally posted by: MergeThis
Complexity may not be the issue so much as foreign code: RH is quite finicky about what it will allow in (it thinks it's saving you from yourself, the helpful little thing!).
You might try making sure that you Save your pasted code before you exit True Code. That sometimes works.
Good luck,
Leon
Just wondering if you have tried compiling the problem outside of RH - say in HTML Workshop? Generate a project with one topic (with your spliced grahpic) and generate. If it works, the fault is with RH. If it doesn't, the problem is with the HTML Help engine that RH uses and won't work no matter what you do. Could be worth trying if for no other reason than to discover where the problem lies.
...and just what the heck is "a sliced graphic"?
Hey, how can you learn, day after day, if you don't ask, right?
See Image Maps under Images and Multimedia in the RH help.
Sounds like you might be able to accomplish what you need without a table full of slices.
Yeah, no solution seems to be free of some downside...
Good luck,
Leon
