Hello;
I'm trying to make 2 types of page navigation work together. both work fine independently, but when I put my next n record code together with my change order by code, when you hit the next button, it goes back to the set default for the order by. I know I need to change some code logic in my scripts that run the next n records, but I'm not sure what I need to change in it to make it all work together properly. I am attaching the code, in it's rawest form, but all code is here for both features.
<cfparam name="sort" default="1">
<cfquery name="getMerch" datasource="#APPLICATION.dataSource#">
SELECT merchID, MerchName, MerchDescription, MerchPrice, MYFile, CategoryID
FROM Merchandise
WHERE CategoryID = 2
ORDER BY
<cfswitch expression="#sort#">
<cfcase value="1">MerchName</cfcase>
<cfcase value="2">MerchPrice</cfcase>
</cfswitch>
</cfquery>
<cfset rowsPerPage = 3>
<cfparam name="URL.startRow" default="1" type="numeric">
<cfset totalRows = getMerch.recordCount>
<cfset endRow = min(URL.startRow + rowsPerPage - 1, totalRows)>
<cfset startRowNext = endRow + 1>
<cfset startRowBack = URL.startRow - rowsPerPage>
<cfoutput>
<!--- changes the order by --->
<cfif sort is 1>
<a href="#CGI.script_name#?sort=#IIF(sort is 1, '2', '1')#" class="pre2Nav">Order By Price</a>
<cfelse>
<a href="#CGI.script_name#?sort=#IIF(sort is 2, '1', '2')#" class="pre2Nav">Order By Product</a>
</cfif>
<!--- my next n buttons --->
<cfif startRowBack GT 0>
<a href="#CGI.script_name#?startRow=#startRowBack#" class="pre2Nav">< Back</a>
</cfif>
<cfif startRowNext lte totalRows>
<a href="#CGI.script_name#?startRow=#startRowNext#" class="pre2Nav">More ></a>
</cfif>
</cfoutput>
<cfloop query="getMerch" startRow="#URL.startRow#" endRow="#endRow#">
<cfoutput>
All my output goes here
</cfoutput></cfloop>
Can anyone help me get this to work together? is it possible? and more importantly, how hard is it going to be to do this?
Thank you.
What is the value of sort when you look for the next n records?
the value is changed to 2 if you click the link, that's when next n record fail. when it's set to the default, which is 1, it's fine.
The problem is either that the variable is not what you expect, or that your switch case code is wrong. Try this
<cfdump var = "isDefined('sort')>
<br>
<cfdump var = "sort is #sort#">
<br>
</cfswitch>
Do you get the expected results?
It works fine, I get the proper results, accept when I hit next, then it goes back to the default #sort# that is 1 for the next set of records.
I believe the next n code needs to have stipulations in it for the #sort# setting, but I'm not sure how to approach that.
What did this give you when you hit next?
if I use this:
<cfdump var = "#isDefined('sort')#">
I get YES as the output, even when I hit the next button and change the category.
If I use this:
all I get is this:
isDefined('sort')
Ok, I forgot the octothorps. Try this:
<cfif isDefined('sort') is true>
<cfelse>
no variable named sort
</cfif>
<br>
Then press next. The objective is to see what is being passed and whether or not it's changing.
when I put this code in I get this:
when it loads the page I get: sort is 1
I click on changing the order I get: sort is 2
when I click on next and it's set on sort is 2 It goes back to: sort is 1
does this help?
Your original post does not show anything that would pass a variable named sort when you click next.
that's what I'm asking for help with, I'm not sure how to make the links know the difference between the
2. Obviously it's going to use an if statement for 2 different links, but what would the code be in the link to realize it's been sorted differently?
after doing all this dumping looking for the variable.. can you help me figure out what to put in a link to
make this work?
