1. Re: Event Gateway for Weblogic JMS
BKBK Mar 24, 2010 12:48 PM (in response to HeyKen93)I do believe it is possible. You will need just 2 files: a CFC and a CFG.
I'll refer to 2 pages in the livedocs, namely:
Developing an event gateway application
and
Using the example event gateways and gateway applications
You need the CFC and the CFG(configuration) file to create an instance of the JMS gateway. The CFC is the gateway's listener. You will have to register its full path when you create an instance of the gateway (for example, your 'testJMS') in the Coldfusion administrator.
A simple test example of such a listener CFC contains just one method, namely, onIncomingMessage. The first reference contains an example.
To get an idea of the CFG file, see the example that comes with your Coldfusion installation. You will find it at
{CF_INSTALLATION_DIR}\gateway\config\jmsgateway.cfg
That example works only for JRun Topics, not even Queues. But it contains clues for you. Here's where you have to do some searching.
Search for the Weblogic values for the following.
queueName=name_of_your_Weblogic_queue
providerURL=a_standard_weblogic_configuration
initialContextFactory=a_standard_weblogic_configuration
queueConnectionFactory=name_of_your_Weblogic_queueColdfusion will use the providerURL to connect to Weblogic, and the initialContectFactory to know how to fetch queues by name. I once used the following with JORAM(a JMS provider you can loosely compare with Weblogic)
QueueName=myClientService
providerURL=scn://client.myDomain.com:16400
initialContextFactory=fr.dyade.aaa.jndi2.client.NamingContextFactoryQueueConnectionFactory=myClientQConnFactory
Save your own 4 lines(for Weblogic) as, for example,
{CF_INSTALLATION_DIR}\gateway\config\test_jms_gateway.cfg
Then use this full path, together with that of the CFC above to fully define the JMS gateway instance in the administrator. The second reference above shows you the content of the event struct that the listener CFC listens to. For example, whenever a message arrives in the Weblogic queue, the listener CFC will pick it up as arguments.CFEvent.data.msg (assuming you copied the CFC example referenced above).
You will of course want to record the message. Use the cflog tag.
2. Re: Event Gateway for Weblogic JMS
BKBK Aug 16, 2010 10:47 PM (in response to HeyKen93)Anyone tried the suggestions I gave? What was the result?
