I create a file in Captivate, then publish it as a .swf file.
I import it into my higher-level Captivate file and preview the entire project.
The imported file plays all right initially, but sometimes it stops before the last slide is played.
For example, I have a file that is 11:03 minutes long. It is composed of 99 slides. It refuses to play past the 71st slide.
I've played around with the timing settings (Properties > Options tab). Setting the "display for" setting to:
Anyone else have this issue? I've tried to determine if there's a file size max, but sometimes larger files play successfully and smaller ones don't.
TIA.
Justa thought...but how about making sure your pauseis set for 11:05to ensure itdoesn't p
revent theswf from playing all the way through.
Rita
