Every time I open my RH8 merged webhelp system in IE8, I get the following warning message:
Anyone have any recommendations about what is causing this and what workarounds are available?
thanks
This page seems relevant to the cause of th e message.
http://tinyurl.com/ycuc6wt
What I am not understanding is why you get that on opening the help. Is the default topic trying to access something? Maybe with the information in the link above, you can figure out what is happening.
Interested to know what you find.
Well, after some experimentation the following cleared up the problem.
1. Delete all contents of the Output and Published folders.
2. Generate all of the content again, this time selecting the content to be W3C compliant AND NOT have the "Mark of the Web".
3. Republish all help.
This clears up all the security warning issues.
Mark of the Web is really only for when the help is run locally but thanks for posting back that it caused this problem with your published output.
