Acrobat is unable to connect to your email program
Jun 01, 2009 Jun 01, 2009
I've done a fair amount of research with little to no success on this issue. I am using latest version of Mozilla Thunderbird and works just fine on my WinXP machine. I am currently running Vista Ultimate. Version of Acrobat is 9.1.1 [after recent update]. I have already done the basic troubleshooting (i.e. Set Thunderbird as default mail client within Vista and Thunderbird).
Acrobat is the only program I am having issue's with in this regard. Every other program I have recognizes Thunderbird as the default program. I've done a complete un-install w/complete registry cleanup, re-boot, re-install and update with still no light at the end of the tunnel.
Any other idea's would be greatly appreciated....Adobe have a "Default Mail Client install program"?? I do not see any settings within Acrobat under the "Preferences" tab.
Thank You
87.6K
New Here , Feb 01, 2010 Feb 01, 2010
I found a way to make this work. It boils down to setting Thunderbird as default in a very specific way - even if you think it already is the default, it will only work in this way. I'm using Windows 7 Profssional and Acrobat Pro 9.0.
Here' how: Start > Default Programs > Set program access and computer  defaults > Custom (expand this) > Choose a default e-mail program
Then, click on 'Thunderbird'. - 'Use my current email program' won't do it, even if Thunderbird is already your default.
I can now
Acrobat has only a few email clients it supports. I can only guess that the new Thunderbird is not among the clients it supports. If you want it to support Thunderbird:  https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
I thought that some of the e-mail issues had been improved with AA9. You are likely running into the issue that is why we do not recommend e-mail submission of forms. E-mail interaction depends on the settings of the client and in the past has required MAPI to be active on the system to activate e-mail. I have heard that some of the web clients have worked, but I am not sure if that is because they use MAPI or what. In any case, look for MAPI. You might do a search in the manual (HELP) to see if MAPI comes up. It does in older versions of Acrobat. Bill
I thank you all for your responses. I guess the pill that I have a hard time swallowing is that this exact configuration exists flawlessly on my XP machine yet, on my Vista machine, it doesn't even recognize there being a default program. AA8 worked just fine on my Vista machine (as well as played nicely with Thunderbird). I am not a programmer but, seems relatively simple for the two (2) programs to talk to each other. Sounds like it uses a "Mailto:" protocol yet...regardless of what the system has set....AA9 doesn't recognize it...
Is Adobe.com Tech's aware of this issue? I did a search through the KB and didn't find much...
Thanks again for your assistance..
You have to set your email program to use MAPI. This is listed in the Acrobat JS API Reference.
After doing some research, TB is capable of SimpleMAPI not, ExtendedMAPI. If anyone know's of a setting within TB to change this, I'd be ever so grateful however, looking like this isn't going to work on my Vista machine....once again, still stuck with the issue that both scenario's are identical, with the exception of the OS.....with XP working and Vista not.....regardless of MAPI settings, etc....as....it seems to have no effect on my  XP machine and I only use TB as a mail client. All others removed or un-installed.
As far as I know, Acrobat only requires simple MAPI. That is all I use with my mail package. The question is if any form of MAPI is active?
Jun 02, 2009 Jun 02, 2009
According to TB KB's and Forums's, MAPI is automatically activated once you set it as default mail program. In the event of a corrupt file, I did delete and re-install TB last night....AA9 still does not recognize TB as a mail program.
I can now email my pdf documents from Acrobat.
Feb 08, 2010 Feb 08, 2010
THANK YOU SO MUCH for this solution, qertw22!! That setting of the default email program worked like a charm! I have been irritated by this problem since buying my Windows 7 setup 3 months ago. You're a genius!!
Keep in mind that if you create forms with a "mailto:" submission, you have no control over fixing the e-mail problems on a client machine as you have just done for yourself. Your problem is a good example of why not to use e-mail submission.
Mar 18, 2010 Mar 18, 2010
Thanks!!!!!! This solved it for me too
Mar 25, 2010 Mar 25, 2010
I don't know how to mark your answer as CORRECT, but it is CORRECT!
Apr 28, 2010 Apr 28, 2010
Right on gertw22! You solved it!
Aug 10, 2010 Aug 10, 2010
This is the solution! Thanks.
Thank you. It worked!
Apr 12, 2011 Apr 12, 2011
Well done gertw22, that is the answer I needed. Fixed my problem on win7 with Thunderbird 3.1.9 and Acrobat pro 9.4.3. Several of the other answers listed here were not helpful or even bad advice.
Oct 28, 2011 Oct 28, 2011
This solution worked perfectly for me!!  Thank you so much for your advice.
YES, this solved my problem, too. I started having problems when I changed to Windows 7. I was so frustrated to see that I had LOST functionality. Now I'm a happy camper. Thanks!
Mar 27, 2010 Mar 27, 2010
I am running into the same problem except I am running Thunderbird version 2.0.0.24 on a Windows XP machine. The pdf form was created using Acrobat 9 Pro, but it doesn't matter if I try to fill it using Acrobat reader 9 or Acrobat Pro--both just seem to see Microsoft Outlook.  Other things find Thunderbird just fine--mailto links in websitesfrom both Firefox and IE, and hyperlinks in Word documents.  I have double-checked the default mail program in the control panel, and checked that Outlook Express knows it is NOT the default mail program, but I could not find a similar function in Outlook.  I've tried downloading and running the DefaultMail freeware program that was suggested on the MozillaZine KB, but that didn't seem to help either.  Anybody got any suggestions??  Thanks.
Nov 26, 2010 Nov 26, 2010
You must go to this link,
http://support.microsoft.com/kb/963707
remove .NET Framework Assistant plug in Firefox
Delete this and it will work...again, took me weeks to figure it out!
It is a plugin your friends at Microsoft secretly add to your Windows registry without permission to make your Mozilla Software go wacked,
That way they get frustrated and intice you to go back IE and OE
Not me!!!!!!!!!!
Hint: Do not delete the whole Foundation folder just the NPWPF.dll in it.
MIcrosoft wants you to delete the whole Folder, do not do it just the .dll file in it
This will also help you copy and paste in Firefox again and will make your default e-mail client e-mail with T-Bird again & not OE
Microsoft updates - are't they great? - NOT - turn them off - "automatic"ally for good!
Guest
Aug 18, 2010 Aug 18, 2010
Worked for me too.  Thanks so much.
That way they get frustrated and intice you to go back to IE and OE
Not me!!!!!!!!!!
Microsoft updates - aren't they great? - NOT - turn them off - "automatic"ally for good!
Dec 02, 2010 Dec 02, 2010
Am having similar problem. Recently updated from MAC Office 2008 to MAC Office 2011. Acrobat (9.4.1) initially asked me "Where is Entourage?" and when I selected Outlook 2011 nothing happened. Now when I select Attach to Email, I simply get an error message "An error occurred while trying to create a mail document.  Acrobat is unable to complete your request."
I have checked the MAC Mail system preferences and they are set with Outlook as the default email service.
Any ideas?
Dave
Guest
Jan 11, 2011 Jan 11, 2011
http://objectmix.com/adobe-acrobat/250279-problem-attaching-file-email.html
Not sure if this will help but you can try if you are comfortable using the
registry editor
. Some how Vista does not seem to set the default email
client properly for other programs to use. I found this out when trying to
send email from within Adobe acrobat like yourself.
From start menu Run/regedit and open it
Then go to
HKEY_LOCAL_MACHINE\SOFTWARE\Clients\Mail
In the right pane you sill see a value (default). Right click on that and
select modify. If Windows Mail is not in there then type it in and
close the editor.
In my case it had Outlook and was opening Outlook even though WM was my
default client
Bill
