I cannot get the Remote Server access working in CF Builder.
I followed the instructions at:
http://blogs.adobe.com/cfbuilder/2009/07/remote_server_setup_is_it_real.html
When I try to start the server I get:
Cannot perform the operation. Admin server for the remote server **** is not running.
I ran the adminstart.bat file. I noted the ports it reported and updated the configuration for the remote server
Not sure if I have to do something different because it is MX7.
Any help would be greatly appreciated.
It appears I have moved slightly ahead in that the server, after starting, hangs at "Starting." When I attempt to stop it, I get:
"Server is not responsive."
I have tried using "Admin" for the RDS Username, as well as leaving it blank (sinct there is no way to configure a rds username in mx7). Not sure if that's even the issue though.
Do you have the server set up to auto-start or auto-stop when opening and closing CFB? If so, try disabling those settings and starting the server using the services manager.
No, I don't have it set to auto start/stop. These attempts to start the server have been from the Servers tab.
Does CF start and stop just fine via Windows Services?
Yes, I can start and stop CF through windows services with no issues.
It does sound like an issue with CFB. Please let us know if you figure that out. I am running CF9 on my local server and it is able to start/stop services from CFB with no problem.
Have you updated the {CFHome/runtime/lib/security.properties to include the IP address on the computer you are running CFB?
Yes, I had edited that file for the IP address and subnet mask.
We are installing CF9 on a devlopment machine this week so hopefully I'll have better luck with that. If it does work, at least that will be more of a push to mangement to get going on CF9 in production as well.
I have given up on getting CFB to work with my MX7 server. Very frustrating, but thankss for trying to help SpiderFromMars. I really appreciate it.
