This is WEIRD.
We have two CF servers, ver 7.? and 8.? on different boxes.
7.0 is production, 8.0 developer.
In the 7.0 server we see the value of now() being 1 hour different from the value of now() in the 8.0 server.
Both servers within the Windows environment show the same time value in the system tray.
Nowhere do we see - never looked for it - a Daylight Savings time override in CF 8.0. Is there one?
Why should it be different than Windows itself.
Both servers are running Windows 2000 Server. Ok, they boxes aren't QUITE as old!
Our workaround is to save data to our DB server based on a getdate() value in the DB server rather than bogus data.
Are we overlooking something REALLY simple?
Robert
Check the TZ SETTING. I think it is in the JVM config.
Thanks for the reply ...
Unfortunately that does not seem to be the culprit ...
The JVM Argument field looks like:
-server -Dsun.io.useCanonCaches=false -XX:MaxPermSize=192m -XX:+UseParallelGC -Dcoldfusion.rootDir={application.home}/../ -Dcoldfusion.libPath={application.home}/../lib
You don't have an old unpatched JVM do you?
http://www.theregister.co.uk/2007/03/09/java_time_bug/
Adam
Read the article with thanks.
Based on their description, it would not affect a simple now() as it seems to need to include time zone references.
In addition, as of last night, the UK is on the same time zone we are on ... (client has a UK office) ... but this server was purchased in the USA in their US data centre.
I am lost ... how does one update JAVA on a server?
Speaking of OLD, their production server is older than the dev box by 2-3 years so I would suspect the other way 'round.
I did just reboot the dev box on a prayer (should have tried that sooner) and no luck.
what does this tell you? is it the same for both servers (the tzName should be,
the JRE for cf7 & cf8 should be different)?
</cfscript
What tzName? There is no reference to tzName in the JVM arguments in either server.
rats, the forums swallowed my off-the-top-of-my-head-code. it doesn't like tags
in email responses. pretend this is wrapped in cfscript tags & there's br tags
in the output:
tz=createObject("java","java.util.TimeZone").getDefault();
tzName=tz.getDisplayname(true, tz.LONG); // default tz long name, DST if used
jre=createObject("java","java.lang.System");
JREname=jre.getProperty("java.runtime.name");
JREversion=jre.getProperty("java.runtime.version");
writeoutput("JRE: #JREname# #JREVersion# timezone: #tzName#");
When I run that cfscript on the CF8 box, I get ..
JRE: Java(TM) SE Runtime Environment 1.6.0_04-b12 timezone: Central Daylight Time
On the CF7 ox ...
JRE: Java(TM) 2 Runtime Environment, Standard Edition 1.4.2_05-b04 timezone: Central Daylight Time
As it's the CF7 box that is working fine, I would think I would leave IT alone! ?
Is the the JVM Version number as well?
Robert
The 1.4.2_05 version of the JVM does not account for daylight saving time changes. You should update to a newer JVM, 1.4.2_11 or 1.4.2_15, to address your time zone issues. This is covered in the link I posted previously.
But that's the box that IS working!
It's the CF8 box that isn't, (and the CF7 being production AND being replaced in 6 months, we're not touching a box thats working fine.)
Robert
perhaps you've just got things twisted around?
Just in case my brain was fried, I just checked it and rechedked it! ... no, nothing is twisted around ...
what exactly is your reference that the cf8 server is an hour off & is the
server that's wrong?
does getTimeZoneInfo() return the same data for both servers?
i think that "JR" is correct & the cf7 box should be the "wrong" one & you might
need to update the JDK. can't quite understand why you think the cf8 box is the
"wrong" one.
Ok, we ran that code snippet and the snippet from Adobbe docs ... on both servers ...
On the CF8 box, the one that where now is an hour off the system clock, we get
Total offset in seconds is 18000.
Offset in hours is 5.
Offset in minutes minus the offset in hours is 0.
Is Daylight Savings Time in effect? YES.
On the CF7 box ...which yields the correct time.
Total offset in seconds is 21600.
Offset in hours is 6.
Is Daylight Savings Time in effect? NO.
Both servers (Windows boxes) are set to Central Time, Observe Daylight Savings time.
if you run the testbed here:
http://www.sustainablegis.com/projects/tz/testTZCFC.cfm
and pick your tz (CST, etc.) it says you're in DST. guess cf7 is wrong (as "JR"
already noted) unless you're in one of those regions that doesn't observe DST?
Really appreciate all these suggestions ...
on the box that is working corectly ... cf7.
server datetime :: 30-Mar-10 02:37 PM
server timezone :: Central Daylight Time
selected timezone :: America/Chicago
raw offset :: - 6.00 hrs
offset :: - 5.00 hrs
DST savings :: + 1.00 hrs
uses DST :: YES
in DST :: YES
cast to UTC :: 30-Mar-10 07:37 PM
cast from UTC :: 30-Mar-10 09:37 AM
cast to server :: 30-Mar-10 02:37 PM
cast from server :: 30-Mar-10 02:37 PM
on the box that is NOT working ... almost exactly the same.
server datetime :: 30-Mar-10 02:43 PM
uses DST :: YES
in DST :: YES
cast to UTC :: 30-Mar-10 07:43 PM
cast from UTC :: 30-Mar-10 09:43 AM
cast to server :: 30-Mar-10 02:43 PM
cast from server :: 30-Mar-10 02:43 PM
unfortunately my tz CFC works independent of the cf serve tz so its going to
give you correct tz results no matter what, i was only using it as a reference
to point out that your cf7 box looks to be setup wrong. as of today CST tz is
in DST.
What JVM is your CF7 server running?
I suspect that you will need to update the JVM on your CF7 server. See reference from Adobe below.
http://go.adobe.com/kb/ts_d2ab4470_en-us
JVM version ... is that the same as below?
