5 Replies Latest reply on Mar 31, 2010 1:55 PM by Xavier Agnetti
    Unable to find resource 'com.adobe.flex.framework:playerglobal:swc:10-3.2.0.3958' in repository snap
    clintmodien Level 1
      I filed a bug about the asdoc rules and I thought I'd try and fix it myself...
      I checked out the source at http://opensource.adobe.com/svn/opensource/flexpmd/tags/1.1/
      I cracked the terminal on OS X and went to the flex-pmd-parent dir and ran mvn package
      After much weirdness... (I'm a maven n00b)... I ran into a problem...
      If someone can point me in the right direction to get this to work... I'd be more than happy to write a patch for the bug I filed..
      Thanks in advance...
      Error below:
      Downloading: http://fna-v2.googlecode.com/svn/trunk/fna_m2_repository//com/adobe/flex/framework/playerg lobal/10-3.2.0.3958/playerglobal-10-3.2.0.3958.swc
      [INFO] Unable to find resource 'com.adobe.flex.framework:playerglobal:swc:10-3.2.0.3958' in repository snapshot-fna (http://fna-v2.googlecode.com/svn/trunk/fna_m2_repository/)
      [INFO] ------------------------------------------------------------------------
      [ERROR] BUILD ERROR
      [INFO] Failed to resolve artifact.
      Missing:
      1) com.adobe.flex.framework:flex-framework:pom:3.2.0.3958
        Path to dependency:
            1) com.adobe.ac:flexunit-theme:swc:1.1
            2) com.adobe.flex.framework:flex-framework:pom:3.2.0.3958
      2) com.adobe.flex.framework:playerglobal:swc:10-3.2.0.3958
        Try downloading the file manually from the project website.
        Then, install it using the command:
            mvn install:install-file -DgroupId=com.adobe.flex.framework -DartifactId=playerglobal -Dversion=10-3.2.0.3958 -Dpackaging=swc -Dfile=/path/to/file
        Alternatively, if you host your own repository you can deploy the file there:
            mvn deploy:deploy-file -DgroupId=com.adobe.flex.framework -DartifactId=playerglobal -Dversion=10-3.2.0.3958 -Dpackaging=swc -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
        Path to dependency:
      2 required artifacts are missing.
      for artifact:
      from the specified remote repositories:
        snapshot-fna (http://fna-v2.googlecode.com/svn/trunk/fna_m2_repository/),
        flexmojos-repository (http://repository.sonatype.org/content/groups/public/),
        central (http://repo1.maven.org/maven2),
        snapshot-codehaus (http://snapshots.repository.codehaus.org),
        dist.codehaus.org (http://dist.codehaus.org/),
        maven2-repository.dev.java.net (http://download.java.net/maven/2/),
        apache-snapshots (http://people.apache.org/maven-snapshot-repository/),
        apache (http://cvs.apache.org/repository/)
