1. Re: Using the scale tool
Michel Bozgounov Mar 29, 2010 3:15 PM (in response to Stuart Haiz)Select an object. Press "Q" and you can use Scale tool on it. Wanna de-select this object and select another one? Double-click outside of the object, and Scale tool is no longer selected. Then simply click on another object, press Q and use Scale tool on it. And so on.
This is how I do it... You don't need to press ctrl/cmd to exit temporarily Scale Tool mode. And if you need to simply go around the document (use hand tool, for example, while still having selected the Scale tool), just press SPACE, navigate to where you want, release space, and continue working with Scale tool on the previously selected object...
Hope this helps!
2. Re: Using the scale tool
Stuart Haiz Mar 30, 2010 1:46 AM (in response to Michel Bozgounov)Thanks Michel
I'm still getting used to the way Fireworks operates, having been a PS user for years!
3. Re: Using the scale tool
Michel Bozgounov Mar 30, 2010 1:49 AM (in response to Stuart Haiz)Glad I helped!
Fireworks is much more intuitive than Photoshop. Please, if you have any other questions, do not hesitate to ask them in the forums!
4. Re: Using the scale tool
Stuart Haiz Mar 30, 2010 2:06 AM (in response to Michel Bozgounov)I've moved over because I really like the pixel-accurate drawing tools and site prototyping features. I'm sure that it won't take too long to get used to FW.
Cheers!
