I read on http://www.grainge.org/pages/authoring/browsers/browsers.htm that this was fixed in RH 7.0.2 - did the fix not make it into RH 8.0??
Take a look at Using RH8 on my site.
I see entries for fixed-size popups, but not for autosizing popups
Do you have the patches applied?
What exactly is the problem with your autosizing popups? Can you post a screenshot? - Use the camera icon to insert the image.
I am running RH 8.0.2.208
The problem is fixed with some popups, but not with others.
I have no negative margins in my css file.
The popup is another topic with only an image in it.
Can anyone help me with this issue?
If you import the topic with the hotspot and the topic that is the popup into a new project, is the problem the same?
If it is, send me the new project. See the contact page on my site.
Doubt I can fix it but I'll understand the problem better and can see if it matches others seen.
