I have met below error in using lcds 2.5.1....
how can i fix this error ?
i have already update commons-http.jar file. but same....
thanks,
flex.messaging.config.ConfigurationException: Unable to create service 'flex.messaging.services.HTTPProxyService' for 'proxy-service' due to the following error: org/apache/commons/httpclient/HostConfiguration.ANY_HOST_CONFIGURATION.
at flex.messaging.config.MessagingConfiguration.createServices(MessagingConfiguration.java:202)
at flex.messaging.config.MessagingConfiguration.configureBroker(MessagingConfiguration.java:84)
at flex.messaging.MessageBrokerServlet.init(MessageBrokerServlet.java:105)
at jeus.servlet.loader.ServletReloader.doInitInstance(ServletReloader.java:70)
at jeus.servlet.loader.PrivateReloader.initInstance(PrivateReloader.java:155)
at jeus.servlet.loader.PrivateReloader.getInstance(PrivateReloader.java:114)
at jeus.servlet.loader.ServletReloader.getServlet(ServletReloader.java:49)
at jeus.servlet.engine.ServletWrapper.loadOnStartup(ServletWrapper.java:100)
at jeus.servlet.engine.ServletManager.doPreloadServlets(ServletManager.java:428)
at jeus.servlet.engine.ServletManager.preloadServlets(ServletManager.java:391)
at jeus.servlet.engine.Context.preloadServlets(Context.java:1129)
at jeus.servlet.engine.Context.doStart(Context.java:1018)
at jeus.servlet.engine.Context.execStart(Context.java:835)
at jeus.management.j2ee.WebModule.preStart(WebModule.java:396)
at jeus.management.j2ee.J2EEManagedObject.start(J2EEManagedObject.java:860)
at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:79)
Total Likes
Do you have the proxy-service defined in the services-config.xml?
Steve
Total Likes
here is our configuration...
Service-Config.xml
<?xml version="1.0" encoding="UTF-8"?>
<services-config>
<factories>
<factory id="springServiceFactory" class="das.fw.flex.SpringServiceFactory" />
</factories>
<services>
<service-include file-path="remoting-config.xml" />
<service-include file-path="proxy-config.xml" />
<service-include file-path="messaging-config.xml" />
<service-include file-path="data-management-config.xml" />
</services>
<security>
<login-command class="flex.messaging.security.JRunLoginCommand" server="JRun"/>
<!-- Uncomment the correct app server
<login-command class="flex.messaging.security.TomcatLoginCommand" server="Tomcat"/>
<login-command class="flex.messaging.security.WeblogicLoginCommand" server="Weblogic"/>
<login-command class="flex.messaging.security.WebSphereLoginCommand" server="WebSphere"/>
<security-constraint id="basic-read-access">
<auth-method>Basic</auth-method>
<roles>
<role>guests</role>
<role>accountants</role>
<role>employees</role>
<role>managers</role>
</roles>
</security-constraint>
</security>
<channels>
<channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
<endpoint uri="http://{server.name}:{server.port}/{context.root}/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<polling-enabled>false</polling-enabled>
</properties>
</channel-definition>
<channel-definition id="my-secure-amf" class="mx.messaging.channels.SecureAMFChannel">
<endpoint uri="https://{server.name}:9100/{context.root}/messagebroker/amfsecure" class="flex.messaging.endpoints.SecureAMFEndpoint"/>
<channel-definition id="my-polling-amf" class="mx.messaging.channels.AMFChannel">
<endpoint uri="http://{server.name}:{server.port}/{context.root}/messagebroker/amfpolling" class="flex.messaging.endpoints.AMFEndpoint"/>
<properties>
<polling-enabled>true</polling-enabled>
<polling-interval-seconds>8</polling-interval-seconds>
</properties>
<channel-definition id="my-rtmp" class="mx.messaging.channels.NetConnectionChannel">
<endpoint uri="rtmp://{server.name}:2038" class="flex.messaging.endpoints.RTMPEndpoint"/>
<properties>
<block-rtmpt-polling-clients>true</block-rtmpt-polling-clients>
<idle-timeout-minutes>60</idle-timeout-minutes>
<!--<client-to-server-maxbps>100K</client-to-server-maxbps>
<server-to-client-maxbps>100K</server-to-client-maxbps>-->
<!-- for deployment on WebSphere, must be mapped to a WorkManager available in the web application's jndi context.
<websphere-workmanager-jndi-name>java:comp/env/wm/MessagingWorkManager</websphere-workmanager-jndi-name>
</properties>
<channel-definition id="my-http" class="mx.messaging.channels.HTTPChannel">
<endpoint uri="http://{server.name}:{server.port}/{context.root}/messagebroker/http" class="flex.messaging.endpoints.HTTPEndpoint"/>
<channel-definition id="my-secure-http" class="mx.messaging.channels.SecureHTTPChannel">
<endpoint uri="https://{server.name}:9100/{context.root}/messagebroker/httpsecure" class="flex.messaging.endpoints.SecureHTTPEndpoint"/>
</channels>
<logging>
<target class="flex.messaging.log.ConsoleTarget" level="Error">
<properties>
<prefix>[Flex] </prefix>
<includeDate>false</includeDate>
<includeTime>false</includeTime>
<includeLevel>false</includeLevel>
<includeCategory>false</includeCategory>
</properties>
<filters>
<pattern>Endpoint.*</pattern>
<pattern>Service.*</pattern>
<pattern>Configuration</pattern>
</filters>
</target>
</logging>
<system>
<redeploy>
<enabled>true</enabled>
<watch-interval>20</watch-interval>
<watch-file>{context.root}/WEB-INF/flex/services-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/proxy-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/remoting-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/messaging-config.xml</watch-file>
<watch-file>{context.root}/WEB-INF/flex/data-management-config.xml</watch-file>
<touch-file>{context.root}/WEB-INF/web.xml</touch-file>
</redeploy>
</system>
</services-config>
Proxy-Config.xml
<service id="proxy-service"
class="flex.messaging.services.HTTPProxyService"
messageTypes="flex.messaging.messages.HTTPMessage,flex.messaging.messages.SOAPMessage">
<properties>
<connection-manager>
<max-total-connections>100</max-total-connections>
<default-max-connections-per-host>2</default-max-connections-per-host>
</connection-manager>
<allow-lax-ssl>true</allow-lax-ssl>
</properties>
<adapters>
<adapter-definition id="http-proxy" class="flex.messaging.services.http.HTTPProxyAdapter" default="true"/>
<adapter-definition id="soap-proxy" class="flex.messaging.services.http.SOAPProxyAdapter"/>
</adapters>
<default-channels>
<channel ref="my-http"/>
<channel ref="my-amf"/>
</default-channels>
<destination id="DefaultHTTP">
</destination>
</service>
Total Likes
Likes
Likes
