4 Replies Latest reply on Mar 31, 2010 8:47 AM by yehuda1233456
    flex effect status
    yehuda1233456 Level 1
      is theire a property for flex effect object that represent his current status?
      something like :
      if(myEffectObj.status == 'end') {
           myEfectObj.play(new Array(myItem));
      sorry again for my english i use to speake hebrew...
      thank you
        • 1. Re: flex effect status
          Matt Le Fevre Level 4
          something like :
          thank you
          something like this?
          myEffectObj.addEventListener(EffectEvent.EFFECT_END, doThis)
          public function doThis(evt:Event):void
          • 2. Re: flex effect status
            thank you grizzz
            will this event  take place if the effect never started too?
            • 3. Re: flex effect status
              if you add it as your application starts up, it'll occur whenever the effect ends.
              If the effect never ends, ie: it never occurs
              it'll never call the 'doThis' function.
              there are also cases where you want to remove the listener, for which you can use
              myEffectObj.removeEventListener(EffectEvent.EFFECT_END, doThis);
              which'll stop the 'doThis' function from being called whenever an effect may end.
              • 4. Re: flex effect status
                OK i found a way to work around with this
                if (arrowMove) {
                     arrowMove = false;
                     shakeRight.addEventListener(EffectEvent.EFFECT_END, function():void {
                          arrowMove = true
                     shakeRight.play(new Array(left));
                thank you!
