404 Error in RDS Connection
Participant ,
Mar 31, 2010 Mar 31, 2010
When creating an RDS connection to the internal CF9 server (127.0.0.1:8500) I get a popup box with a red 'X' saying 'Unable to contact RDS Server "Home."  Error Executing RDS command. Status Code: 404, Reason : Not Found'
Why am I getting this message?
It would be nice if we could connect to a database directly in CFB without having to use RDS. (hint hint)
Builder
3.7K
Participant ,
Can you check whether your CF server configured in RDS is up and running? Also, re-check the details provided in RDS configuration (hostname, port no., RDS username/password etc). You may want to check the context root if it's a J2EE server. You can click the 'Test Connection' button to check the connection everytime you alter the settings in RDS configuration.
Dipanwita
Adobe ColdFusion Builder Team
Participant ,
Apr 05, 2010 Apr 05, 2010
Do you know of an easy way to check if RDS is up and running? I did a clean install of CF9 on my local machine and I thought that the default was to have it on.
Participant ,
In the default ColdFusion prespective in CFB, check if you can access files through RDS Fileview and the datasources on your CF9 server through RDS Dataview.
Dipanwita
Participant ,
Apr 06, 2010 Apr 06, 2010
But, how can you check in the ColdFusion administrator whether or not RDS in enabled?
Thank you for your help!
Peter
Jan 08, 2023 Jan 08, 2023
I know this is from 13 years ago, but there is an rds tab in the cf admin Security section, which has a checkbox that can be used to confirm or enable rds.
/Charlie (troubleshooter, carehart.org)
Documentation
