Hello, I've found my way to this forum due to a persistent problem I am having. This problem according to the error pop up screen relates to adobe, specifically - Flash 10e.ocx.
I have read the other threads but my issue seems to be different to the ones listed here. I have however taken some of the advice given but still having the same issues.
I have uninstalled and reinstalled adobe and also Java but still the issue persists. I have also rebooted an number of times as well.
Basically what is happening, I am updating text in the back end of a website which I am able to do for about 10 minutes or so then the screen appears telling me that Flash 10e.ocx has encountered a problem with IE and needs to close. IE the closes and needs to be reopened and the same thing continues. Sometimes I don't even get the warning and IE just closes automatically.
I am running Vista and have bever had this issue before.
Any help would be greatly appreciated.
Very confused and annoyed!!!
Hi OCG, Since it is IE that is closing, check in your manage add ons (all add ons) and find Shockwave Flash Object...
ActiveX Control...Flash10e.ocx and make sure it is enabled. This is the ActiveX Control that must be installed and the latest version is 10.0.45.2, as it works with the Flash Player files.
If you have that, then we would want to check your Flash files to see what is installed. Go go C:\Windows\System32\
Macromed\Flash. Right click on the Flash folder and post back all files listed there.
eidnolb
Dear eidnolb,
Thank you very much for all the info. I checked in my add ons and all I see in the list is something that says "Shockwave flash object" and it is enabled. I checked all the different lists and couldn't find anything that specifically said it was the Flash 10.... Anyhoo, I then followed the next set of your instructions and this is what was in the flash folder: Flash103.ocx ActiveX control, Install text document, FlashUtil10e & uninstall Active X. Those are the only things in the folder. Any further help would be greatly appreciated.
Thanks again
Hi, In your Flash folder if the Flash103.ocx was just a typo and you meant Flash10e.ocx then your files are correct.
However, I am somewhat puzzled that the add on in all add ons is not complete. It should list as Shockwave Flash Object...ActiveX Control..Flash10e.ocx... enabled.
If this SFO is not installed then that would account for the error you are receiving. This .ocx is an ActiveX Control, it is installed in the Flash files, so the error is not pointing to that. The only thing listed is Shockwave Flash Object and enabled? Nothing else?
What Anti-Virus/Spyware are you using and does it contain a Firewall? If it doesn't do you use any Firewall other than
the Windows Firewall?
What IE version?
eidnolb
I have Shockwave Flash Object...ActiveX Control..Flash10e.ocx... enabled.
I have antivir as an antivirus, it contains no firewall.
Windows' firewall is disabled, I use ZoneAlarm.
I juste made sure Flash was OK in the firewall, tested again and it crashed.
AppName: iexplore.exe
AppVer: 8.0.6001.18702
ModName: flash10e.ocx
ModVer: 10.0.45.2
Offset: 001f3505
Ok.... so I have windows XP and I noticed when I was checking in the add ons that I was using the 32 bit, if that helps. My antivirus is McAfee and it does have a personal firewall that is enabled and the windows firewall is enabled as well. I didn't seem to ever have this problem until I "updated" my flash player... go figure, lol. Thanks again for your help. It's greatly appreciated
Sunny, why are you on this thread? I replied to you on your own thread that you started. It is too confusing to have more than one person on a thread. Since I have not received a reply from OCG2010 who started this thread, I will wait for that.
You had no right to answer my post to OCG2010. So from now on, you will be ignored. Instead of posting on someone else's thread you should have replied to me on your own thread, since I took my time to respond to you.
To Chose1977, you also need to start your own thread. And if anyone else decides to post on this one, the same applies
to you also.
eidnolb
To OCG2010, excuse the rudeness of Sunny and Chose.
It's ok, don't worry about that !
I started a new thread.
Really? I posted on this thread because we were ALL having the same problem so I figured it would be easier for you to answer on here, rather than go back and forth between multiple posts. I guess that's my bad for trying to think about others, since you are the one being rude on here not me. I do believe I even thanked you multiple times on here for your time and help. Why in the hell are you making such a big deal about it? I mean seriously.
Sunny, I make a big deal out of it because everyone's system is different. XP, Vista, Win7, IE6, IE7, IE8, Firefox, Safari, Chrome, all different Anti-Virus/spyware/Firewalls, not to mention various Toolbars, All of the Add ons in IE, the plug-ins in FF and other browsers, Security settings, Java, etc. etc. That's why.
If you were on this side of the forum you'd understand. I know many people think it is helpful to post on a thread that is
similiar to their problem. And from your viewpoint I would agree. But those of us on this side look at it differently. You know what you have on your computer, etc. I can't keep in my head 3-4 different people's systems and all of the different
above mentioned.
When you have your own thread, then I can refer back to the posts that I know pertain just to you and your issues. Otherwise, I have to read everybody's until I find that last thing you posted, then find the last thing I posted to you, in between everyone else. No, it's very confusing and it wastes my time and the users also.
Just look at things from this side. The view is always different depending on whether one is looking out or in:-)
eidnolb
Hi eidnolb, aplologies for taking a bit to reply but been doing the Good Easter Friday thing with the family.
I checked the addons and yes the Shockwave Flash was enabled, however I couldn't locate where I was able to confirm if it was the latest version 10.0.45.2. I believe it should be as I have uninstalled and reinstalled a few times, each time I have also rebooted my computer as well.
The files I have listed in my System32/Macromed/Flash folder are as follows:
Flash10e.ocx
FlashUtil10e
install (text doc)
uninstall_activeX
I hope this is what you are after.
Thanks for your help with this also
Cheers
OCG2010
Hi OCG, thanks. No problem on the delay, as you could tell there was plenty to keep me busy on your thread:-) This being Good Friday, I am limiting my time on the Forum to those that already started their threads that I responded to.
Your Flash Player files are correct. Check your add on and make sure it is listed Shockwave Flash Object, not just Shockwave Flash. The Shockwave Player also has a Shockwave Flash add on but it is completely different than Flash Player's add on which is Shockwave Flash Object. Confusing I know, but that is the way it is. I just need to make that
distinction. You should have the SWO either listing with it Flash10e.ocx or version 10.0.45.2 or both.
You can try this, go to Tools, click on Internet Options, click on Settings, then click on View Objects. Is the Shockwave Flash Object listed there with the version number?
What version of IE are you using? This dictates what you can and can't do.
Now you might also mention what Anti-Virus/Spyware/Firewall you use. Even tho you have the correct Flash Player files
installed in the Flash folder, the SWO/ActiveX Control could have been blocked from installing.
Do you use any ad block software or pop-up blockers?
eidnolb
Hi eidnolb, I checked my addon and it is Shockwave Flash Object Flash10e.ocx. Now without trying to confuse you that is listed when I went and checked under tools/manage addons/enable or disable addons. When I went and checked, as you asked me to, tools/internet options/settings/view objects shockwave isn't listed there at all. There was only Java and the following -
{8FFBE65D-2C9C-4669_84BD-5829DC0B603C} Unknown 4KB None None 1.0.0.29
{E2883E8F-472F-4FB0-9522-AC9BF37916A7} Damaged None 2/11/2006 2/4/2010 1.6.2.63
Diagnostics ActiveX WebControl Installed 128KB 10/5/2009 10/5/2009 1,0,0,12
I am running IE version Version 7.0.6001.18000
I am also running AVG anti virus. This includes spyware and firewall.
Hope I have answered all the questions for you?.
Cheers OCG2010
Hi OCG, Ok, glad you cleared up the SWO. Mine is listed in the Settings>View Objects so I thot maybe yours would be too,
in case you couldn't find the version number. Not all of my add ons are listed there, so no biggie. I don't know how it's
decided what is listed there and what isn't.
The "Unknown" file and the "Damaged" file that is listed there, if you can right click on it and Remove/Delete that is what I would do. I had a couple last year and just removed them. Now I use IE6 and have that freedom:-), but you may not with IE7, but try. You never want an unknown add on and a damaged one doesn't do anything to help.
Since you have all correct Flash files and the SWO, then something else. Now I am somewhat familiar with AVG. One thing that conflicts is the AVG LinkScanner. Most everyone agrees on various forums about it.
In your system tray, open AVG User Interface. Double Click on the LinkScanner. Un-tick the option Enable AVG Search-Shield and Enable Active Surf-Shield. Save the changes.
See if this helps.
You also may want to post back all of your IE add ons if the above doesn't help. Something is conflicting and when all Flash files and the SWO are correct then add ons, Toolbars and their add ons, etc.
eidnolb
Hi eidnolb, I was unable to delete those files FYI.
I also disabled the linkscanner and the Active Surf Shield was already enabled. This however didn't help unfortunately.
Here is a list of the IE add-ons as requested.
Add-ons currently loaded in IE
AVG Safe Search AVG Tech Enabled Browser Helper Object avgssie.dll
Google Toolbar Helper Google Inc Enabled Browser Helper Object GoogleToolbar_32.dll
Google Toolbar Notifier BHO Google Inc Enabled swg.dll
SingleInstance Class Yahoo Inc Enabled YTSingleInstance.dll
Skype add-on (mastermind) (Not Verified) Enabled SkypeIEPlugin.dll
Skybot-SD IE Protection Safer Networking Ltd Enabled SDHelper.dll
Yahoo! Toolbar Helper Yahoo Inc Enabled yt.dll
Shockwave Flash Object Adobe Sys Inc ActiveX Control Flash10e.ocx
Blog This in Windows Live Writer Enabled Browser Extension
Java(tm) Plug-In 2 SSV Helper Sun Micro Inc Enabled Browser Help Object jp2ssv.dll
Research Browser Extension
Send To Onenote Browser Extension
Skype (Not Verified) Enabled Browser Extension SkypeIEPlugin.dll
Spybot - Search & Destroy Configuration Enabled Browser Extension
Search Helper Microsoft Corp Enabled Browser Helper Object SEPsearchhelperie.dll
Windows Live ID Sign-in Helper Microsoft Corp Enabled Browser Helper Object WindowsLiveLogin.dll
Adobe PDF Link Helper Adobe Systems, Inc Enabled Browser Helper Object AcroIEHelperShim.dll
Google Toolbar Google Inc Enabled Toolbar GoogleToolbar_32.dll
Cheers OCG2010
Hi, well that is quite a list, I see several conflicts:-) I think you better go to Programs and Features and post back all
Java listings with version numbers. I don't see the Java add ons that should be there.
What I was going to suggest is that you disable all add ons except SWO and Java and see if that would be an improvement. However, we better check the Java files first.
Spybot would probably conflict with AVG since they both have similar components. Skype is a potential conflict, depending on the version. Google, if it was only the Toolbar, probably not. But they add the ActiveX Controls and Google
doesn't play nice with IE anyway.
Let's check Java first and then we can find out which of those add ons are conflicting. It will just be a matter of elimination. You won't have to Uninstall any, we'll just find out which one or more are conflicting.
I notice that the ones you listed are "currently loaded" Do you have "have been used, also?" I have add ons under both listings.
eidnolb
Hi thanks eidnolb, in case you haven't picked up on it yet I am a bit of a computer spaz. Would you be able to direct me to where I will find the java info that you are looking for. Also is there a way of copying all the add-ons instead of typing them out individually?. I know enough to copy and paste but it's not allowing me to do that.
Cheers OCG2010
Hi, We used to have the File attachment but it's been disabled. I know it is a pain to have to type them. Don't feel bad about not knowing everything. I don't know anyone that does:-)
You would find the Java files either Start>Control Panel and double click on Add/Remove or Programs and Features. I'm not sure how Vista is, Win7 is Programs and Features. It would be where all of your programs are listed, if you've ever been there.
We'll address the copying and pasting of the add'l add ons after we see what Java looks like. Hope you're not getting tired of all of this digging, but that's the only way I know to find the problem.
eidnolb
No typing is fine, I just thought I was missing something.
The Java I have installed is - Java (TM) 6 Update 19.
I just thought I would explain the problem that I get also as this may help.
Basically what was happening is, I was logging into a "backend" website builder a friend of mine has. Now without making this to long, everytime I went to add content, basically in the same fashion as this with a similar word type set up and then save it I would get that Flash10e.ocx problem. I hope that makes sense?.
Cheers OCG2010
Ok, not quite sure I understand since I've never attempted what you are doing. But the error is coming from your computer, right? Don't tell me it is your friend's computer or I will be totally confused:-) Well do you think the problem may be with his website? Just ignore my confusion.
Ok, back to Java. You have the latest update. You should have 4-5 Java add ons in IE, do you? Perhaps you won't have to
type add'l add ons. I only need to know if you have the correct Java add ons installed and if so, I wanted you to then
disabled every other add on, both currently loaded and have been used except the Java add ons and the Shockwave Flash Object. But at this point I don't know if you have the Java add ons that should be there.
eidnolb
Hi eidnolb, did mean to confuse you. the add-ons I have are below
Google Toolbar Helper GoogleToolbar_32.dll
Google Toolbar Notifier BHO swg.dll
SingleInstance Class YTSingleInstance.dll
AVG Safe search avgssie.dll
Skype add-on (mastermind) SkypeIEPlugin.dll
Spybot SD IE Protection SDHelper.dll
Yahoo Toolbar Helper yt.dll
Adobe PDF Link Helper AcroIEHelperShim.dll
Google Toolbar GoogleToolbar_32.dll
Java(tm) Plug-In 2 SSV Helper jp2ssv.dll
Research
Search Helper SEPsearchhelperie.dll
Send To Onenote
Skype SkypeIEPlugin.dll
Spybot-Search & Destroy Config
Windows Live ID Sign-in Helper WindowsLiveLogin.dll
Windows Live Toolbar BHO wltcore.dll
Windows Live Toolbar wltcore.dll
Yahoo!7 Toolbar yt.dll
Windows Media Player wmp.dll
Microsoft Silverlight npctrl.dll
Deployment Toolkit deplytk.dll
Free Threaded XML DOM Document msxmi6.dll
XML DOM Document 6.0 msxmi6.dll
XSL Template 6.0 msxmi6.dll
XML HTTP 6.0 msxmi6.dll
QuickTime Object QTPlugin.ocx
Windows Live MSGSC1~1.DLL
Windows Live ID Sign-in Control WindowsLiveLogin.dll
XML DOM Document msxml3.dll
Microsoft Offive 12 Authorisation Control AUTHZAX.DLL
Windows Media Player wmpdxm.dll
InformationCardSigninHelper Class icardie.dll
{9E385F0A-0BA2-430C-96AA-4399C5E40F6C} Sktpe.exe
Quicktime Object QTPlugin.ocx
Adobe PDF Reader AcroPDF.dll
XML DOM Document 3.0 msxml3.dll
Video_X_MS_WMV Moniker Class wmp.dll
Windows Live Upload Tool Microsoft.Live.
QuicktimeCheck Class Micosoft.Live.Folders.RichUpload.3.dll
isInstalled Class wsdetect.dll
iTunesDetector Class ITDetector.ocx
Diagnostics ActiveX WebControl DiagWAPI.dll
XML HTTP 3.0 msxml3.dll
XML HTTP 4.0 msxml4.dll
XML HTTP 5.0 msxml5.dll
Java Plug-in 1.6.0_19 jp2iexp.dll
Cheers OCG2010
You did? LOL, well it wouldn't be the first time I was confused. Ok, I knew there were more. You have the Java add ons, good.
Are you using Firefox or another browser? Just wondering.
Any way, back to the IE issue. Whenever there are many add ons and without a lot of time to disable one at a time and check, sometime it is easier to keep enabled those that are needed and disable all others. Now, keeping in mind that IE
runs perfectly without one add on whatsoever, we will keep enabled Shockwave Flash Object, and Java only.
That means that all Toolbars and every add on "currently loaded" and "have been used" will be Disabled. Then you will try to do what has been causing a problem. If you still get that error, then go back into the add ons and Enable, the Microsoft
XSL, XML's; keeping SWO and Java enabled.
eidnolb
No only using IE and nothing else.
I will try that now and let you know.
Thanks eidnolb. I'll get back to you.
Cheers OCG2010
I have the same problem.
Running WinXP SP3 and IE8.
When I try to play a flash game, it doesn't last long before it crashes (IE) with an error mentionning flash10e.ocx.
Shockware flash object is enabled in the manage add-ons window.
In the folder you asked to list, there are :
Flash10e.ocx
FlashUtil10e.exe
install.log
uninstall_activeX.exe
