Just watched Fortas video and am keen to try out code generation but cannot access it via right click. I dont believe he mentioned it as an extension but
is it adobe cfc generator.zip. If so can someone gently walk me through how to install it on cf builder new release
cheers
ORM Wizard is created by Adobe CFC generator Extension.
You need to install this Extension to CFBuilder to be able to use the ORM Wizard.
You can use the plus button on Extension view to install the extension.
Evelin Varghese
Adobe ColdFusion Builder Team
Tx evelin
whwn I click on the downloaded extension folder
why do i get the server setup page appearing and then not have my local server (which i had earlier set up)
appearing as an option
cheers
Andrew
Hi Andrew,
Have you added the local server to Servers view in CFB? Does it appear there? Can you refresh and check once whether your local server appears in Servers view. If yes, then it should appear in the list of servers for Extensions installation as well.
Dipanwita
Thanks. I'm set up now
