1. Re: Media encoder crashing when exporting h.264
Harm Millaard Apr 7, 2010 8:43 AM (in response to Tayedrummer)Export with H.264 Blu-ray, but in the multiplexer tab, set it to TS instead of the default None.
2. Re: Media encoder crashing when exporting h.264
Tayedrummer Apr 7, 2010 11:26 AM (in response to Harm Millaard)Ok, that worked but Media Encoder wouldn't render out with TS checked using PCM audio, I had to change to Dolby Digital. Once rendered and uploaded to Vimeo the image was displayed as 4:3 but with the anamorphic vertical squeeze even though I was using the 1080p24 preset. <shrug>
I'm wondering if it is the Mainconcept codec that's buggy. Is there an alternative h.264 codec to use with Premiere CS3?
3. Re: Media encoder crashing when exporting h.264
Harm Millaard Apr 7, 2010 1:03 PM (in response to Tayedrummer)It could be the Vimeo encoding that is letting you down. How does the encoded file play on your system?
4. Re: Media encoder crashing when exporting h.264
Tayedrummer Apr 7, 2010 2:07 PM (in response to Harm Millaard)When played back in DivX player it plays back in 4:3 aspect with anamorphic vertical stretch. When rendered out on my first attempt it played back 16:9 aspect.
5. Re: Media encoder crashing when exporting h.264
Harm Millaard Apr 7, 2010 2:36 PM (in response to Tayedrummer)Does VLC or MPC play the file correctly? I always get wary when someone mentions DivX or XVid.
