Hi
Is there a way to define AS3 combobox to wrap long lines?
if cb is your combobox, import the textinput class and use:
TextInput(cb.getChildAt(1)).textField.multiline=true
TextInput(cb.getChildAt(1)).textField.wordWrap=true
I tried to put those two line inside magLoaded function, but I got following error:
ReferenceError: Error #1065: Variable TextInput is not defined.
I use combobox component from library (CBtoc)... I populate it with following code, data comes from XML-file:
function magLoaded(e:Event) {
CBtoc.prompt = magXML.tocHeader[currentMagId];
CBtoc.visible = true;
CBtoc.dropdown.rowHeight = 30;
var tocNumero = CB.selectedIndex;
var tocXML:XML;
var tocLoader:URLLoader = new URLLoader();
tocLoader.load(new URLRequest(magXML.Book.toc[tocNumero]));
tocLoader.addEventListener(Event.COMPLETE, captureData2);
function captureData2(e:Event):void {
CBtoc.removeAll();
var tocXML:XML = new XML(e.target.data);
var il:XMLList = tocXML.article;
if (il.length()==1){
CBtoc.visible = false;
for (var i:uint=0; i<il.length(); i++)
CBtoc.addItem({data:il.spread.text(), label:il.name.text()});
ok, I forgot to import textinput class, now it doesnt give me any warnings but combobox doesn´t wrap long lines either.... do I have those lines in wrong place?
where's the code i suggested?
I took it away before I pasted... sorry
It´s inside magLoaded fuction
TextInput(CBtoc.getChildAt(1)).textField.multiline=true;
TextInput(CBtoc.getChildAt(1)).textField.wordWrap=true;
var tocXML:XML;
is that rowHeight sufficient to display 2 rows of text? increase it.
it should be…
double it and retest.
didn´t work... actually I couldn´t use a value higher that 48.
With value 49 or higher, my drop-down menu turns to drop-up menu.... and because it´s on the top of the screen, opening list goes over the edge ...
i don't think you have enough room to show the 2nd line. take a screen shot after using this code:
TextInput(CBtoc.getChildAt(1)).textField.border=true;
var tocXML:XML;
border appeared around first line only:
there's no room for a 2nd line to display.
can i make it bigger somehow? (it actually shows text in two lines if I make linebreak to xml where those labels are loaded)
without increasing the row height?
yep
and you're NOT using this code to achieve multiline support:
Actually I was using that code when I took a screenshot, but it works also without... but my problem is that in real usage XML will be generated automatically without line breaks, so it´s not a solution...
i don't understand what you're doing.
the combobox labels will not display multiline content unless you code for that. there are a number of ways to do that and i gave one. if you claim you're doing that another way, you haven't explained and if you're not doing anything to make your combobox multiline you're mis-reporting.
Im loading labels from XML. I cant influence to that xml, it comes automatically from other system. Normally labels are quite short and they are always in one line without linebreaks in that xml. I can put some linebreaks to that xml manually for testing it, but thats not a solution for real system.
I´m trying to find a solution to put into that combobox. So that if label is more than, let´s say 30 characters, combobox would split that line into 2 or even 3 lines...
Heres a simplified version of my project, I have stripped everything else off, just a combobox is left there, + of course XML that holds all those labels....
http://dl.dropbox.com/u/133381/cb_test.zip
The smaple provided as download does not work.
Can you please upload a revised sample.
Best
Harry
hmmm...strange, I just tried it and it worked for me... do you get some alert?
You should use a custom CellRenderer like this:
import fl.controls.ComboBox;
ComboBox(dropDown).dropdown.setStyle("cellRenderer", MyCellRenderer);
Class MyCellRenderer
package views
import flash.text.TextFormat;
import fl.controls.listClasses.CellRenderer;
public class MyCellRenderer extends CellRenderer
public function MyCellRenderer()
super();
/ This is another class of the CellRenderer class, which we need
/ to override to set new properties. We change the textField properties.
/ The textField is derived from the LabelButton, which is used for the
/ DataGrid and List components rows and headers. We set wordWrap to true if the
/ text is very long and give html properties to the textField. The string
/ for the textField has the name 'label'.
override protected function drawLayout():void
textField.wordWrap = true;
textField.htmlText = this.label;
super.drawLayout();
I tried your solution. It works partially. The problem is that rowCount is fixed for all rows. Is there any solution for this?
