Issue when tyring to load SWF Module inside a Flex Tile(mc:Tile)
Avatar
Former Community Member
     When i try to load an existing SWF Module inside a Flex Tile using ModuleLoader/ModuleManager (mc:Tile) and trying to run the application using mosaic, I am getting the following error:
VerifyError: Error #1053: Illegal override of FlexModuleFactory in mx.core.FlexModuleFactory.
    at global$init()
However, when i add the TileSDK.swc to the flex project and build the swf and load this swf inside  inside a Flex Tile, the application works fine in mosaic.
But, i having a SWF provided by a third party for which i not having the source code and i want to load this inside a Flex Tile, but i am geeting the above error. Can u explain why this is happening and any workaround?
I also made the following observations:
Type   of SWF to be loaded inside a Tile
With/Without   SDK
Pass/Fail
mx:Application
WITHOUT
Fail
mx:Application
WITH
Fail
mx:Module
Without
Fail
Mx:Module
With
Pass
Mc:ModuleTile
with
Pass
Mc:Tile
with
Fail
Thanks and Regards,
Shyam Sundar.A
ashok.shyamsundar@gmail.com
1 Reply
Avatar
Hello,
a Module Tile (.swc) needs to be compiled with the same version of the Flex SDK like the Mosaic framework. The current version Mosaic 9.0 is compiled with Flex SDK 3.4. Do you know if the SWF Module was compiled with SDK 3.4? Application tiles (.swf) can be compiled with different version of the Flex SDK (3.3 and 3.4).
We recommend to use Application tiles whenever possible and use Module tiles only as an exception (since Module tiles need to compiled with a specific version of the SDK).
Hope that helps,
Matthias Zeller
