Runtimeexception with Modeler Plugin
Avatar
Level 2
I reinstalled FB 4 and installed the Modeler Plugin v101. It worked yesterday. Since today, I cannot open any model files. The FML editor always quits with an error message:
org.eclipse.jface.util.Assert$AssertionFailedException: Assertion failed:
    at org.eclipse.jface.util.Assert.isTrue(Assert.java:185)
    at org.eclipse.jface.util.Assert.isTrue(Assert.java:170)
    at com.adobe.model.derived.editor.FiberMultiPageEditorPart.setActivePage(FiberMultiPageEditorPart.java:757)
    at com.adobe.model.editor.FiberXMLEditor.setActivePage(FiberXMLEditor.java:485)
    at com.adobe.model.derived.editor.FiberMultiPageEditorPart.createPartControl(FiberMultiPageEditorPart.java:291)
    at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:661)
    at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:428)
    at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:594)
    at org.eclipse.ui.internal.EditorReference.getEditor(EditorReference.java:266)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2820)
    at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2729)
    at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2721)
    at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2673)
    at org.eclipse.swt.custom.BusyIndicator.showWhile(BusyIndicator.java:70)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2668)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2652)
    at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2635)
    at com.adobe.model.fb.extensions.handlers.OpenModelHandler.execute(OpenModelHandler.java:206)
    at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:281)
    at org.eclipse.core.commands.Command.executeWithChecks(Command.java:476)
    at org.eclipse.core.commands.ParameterizedCommand.executeWithChecks(ParameterizedCommand.java:508)
    at org.eclipse.ui.internal.handlers.HandlerService.executeCommand(HandlerService.java:169)
    at org.eclipse.ui.internal.handlers.SlaveHandlerService.executeCommand(SlaveHandlerService.java:247)
    at org.eclipse.ui.menus.CommandContributionItem.handleWidgetSelection(CommandContributionItem.java:619)
    at org.eclipse.ui.menus.CommandContributionItem.access$10(CommandContributionItem.java:605)
    at org.eclipse.ui.menus.CommandContributionItem$4.handleEvent(CommandContributionItem.java:595)
Any ideas?
1 Reply
Avatar
Level 1
I had a similar problem when tried to run Modeling plug-in on Eclipse 3.6 thus discovering that the plug-in is incompatible with Eclipse 3.6
"FiberMultiPageEditorPart.addPage" reference found in stack trace
see also http://forums.adobe.com/thread/748772 for more details
I hope this helps
