I'm wondering if, like pmd, flexpmd has a notion of fail.on.error setting?
i.e. using ant to invoke pmd I might do
<antcall target="pmd">
<param name="fail.on.error" value="false"/>
</antcall>
One might want to have a daily build fail on flexpmd errors etc.
Yes there is one: failOnError
You should be good to go with that.
Xavier
Hi Xavier,
We've been using failOnError with some degree of success, but there is a problem..
This parameter causes the build to fail immediately. As a result the xslt transformation task to generate the report of the failing run isn't executed.
We'd rather fail the build in a similar way to the way we fail our flexUnit run, by setting a fail task up at the end of our macrodef:
<fail if="flexPMD.failed" message="PMD failed - check reports"/>
But this would obviously require flexPMD to populate some kind of environment variable with its status.
Is this possible at the moment?
kind regards,
Espen
Hi Espen,
No it is not possible at the moment.
Feel free to create a enhancement for that.
Cheers,
Xavier
