G'day
When one keys in a partial tag, one can press CTRL-SPACE to complete the tag, eg typing:
<cffuCTRL-SPACE
will complete the <cffunction> tag. Cool.
However it takes CFB about 1-1.5sec to actually react to this, during which time if one keeps typing, the tag is never completed. And to be frank, I could have simply typed the rest of the tag name in less time than that. So using this feature makes for very stilted development.
I would expect to be able to type this - at full speed without any pausing for CFB to work out what it needs to do:
<cffuCTRL-SPACEnCTRL-SPACEmyFunctionRIGHT-ARROW acCTRL-SPACE puCTRL-SPACE RIGHT-ARROWoCTRL-SPACEfaCTRL-SPACE RIGHT-ARROW hiCTRL-SPACEHere's my hint
and end up with:
<cffunction name="myFunction" access="public" output="false" hint="Here's my hint">
However I just get this:
<cffu n myFunction ac pu o fa hi Here's my hint
(or something like that, you get my drift).
Are other people finding this tag too? I don't think my machine is under-spec'ed for the task here... it's quite happily running Open BlueDragon, CF9, MySQL (+ MySQL Manager and Query Browser), Tomcat, Apache, Firefox, Skype... [etc] simultaneously, and none of them seem to be slow.
Another thing related to this (kinda). I have "automatically insert single proposals" (or whatever it is) switched on, which is quite handy. However when I type in:
<cfsavCTRL-SPACE
I might expect to get this as a result:
<cfsavecontent variable="|">
(Where the | is the cursor). Because <cfsavecontent> has only the one attribute option, and it's required. It'd be good if CFB was savvy enough to grasp this.
Comment?
Adam
I used to think that autocomplete was slow until I found out that the delay is configurable. If you go to:
Preferences > ColdFusion > Editor Profiles > Editor > Code Assist
You'll see a setting named "Delay before code assist (in milliseconds)"
I set it to 100 and it's a lot zippier now.
Did you check this setting?
Isn't that just the delay for the automatic code completion? I mean as opposed to triggering the code completion with CTRL-SPACE as I am doing.
It's difficult to tell, but I guess it could be slightly faster when I decrease the setting from 2500 to 100. Although it could be because I am editing amuch smaller file than I was last week.
However I am uncertain about this remedy because it's certainly not taking 2.5sec to do the completion when I press CTRL-SPACE, so I do not see the connection between the setting value and the delay here. Plus it makes no sense to add a delay there anyhow: it makes sense before anything happens automatically (and it drives me up the wall when CFB tries to help me when I type without me asking it to); but it makes no sense for there to be a delay after I've explicitly keyed CTRL-SPACE to tell CFB "complete this please".
I guess once I get back to my project work (in the larger files), I'll pay more attention to the completion speed.
Cheers for your suggestion though!
Adam
Whoops! Yeah, you're right. That setting is for the code assist, not the autocomplete. My bad!
And yes -- I've also noticed that sometimes the autocomplete is slow but I didn't make note of whether it was only with large files or not. I'll report back if I have anything more to add.
Any performance differences I perceived earlier certainly were not perceptable once I returned to working in large files.
Adam
