Hi all
I have attached the workflow which I am developing.
The steps that has to follow while developing workflow:
Step1: Initiating
Step2: it should go to SVR for approval and give notification to A1 and A2.
Step3: SVR approves it should go to initiator and notify to A3 and A4.
Step4: Initiator has Accept and Re-submit.
· If Accept it will do nothing
· If Re-submit it should go to step 2 and continue from there on.
i cannot use AND-wait because A1,A2,A3,A4 are acknowledgments only no need to have action for them only SVR and Initiator have to respond in the flow
please hep me out how i can go through this work flow
i have attached my work flow below
waiting forreply
Total Likes
You can still use an AND-WAIT even if A1 and A2 are not tasks but just acknowledgements.
It will go to SVR in the first branch, and in parallel execute the A1 and A2 branches and then wait until SVR is completed before going to the next gateway.
Am I missing something?
Jasmin
Total Likes
thank Jasmin for ur reply
Process should not wait until A1,A2,A3, or A4 acknowledgements, it should
only check weather the route that i marked in Red in the above post
completed or not
if the initiator resubmit it should go back to SVR same time
give acknowledgements to A1 and A2 again
if initiator resubmit the loop should repeat and should not wait for all
the acknowledgements it should check only wht initiator chosen at the end
of gate way 1
Total Likes
I still don't understand why you can't use the Gateway.
Maybe because I don't understand what you mean by acknowledgments. For me an acknowledgment would be an email, a notification or something like that.
So let's say we use the gateway with three branches. The firsts branch goes to SVR (and ultimately to another gateway) and the two other ones send acknowledgments, then here how it's going to work:
The first branch will go to SVR and wait until the user approves the form.
The second and third branches will send their acknowledgments and then go to the end of the gateway.
When SVR completes, then it'll go to the next gateway (still in the first branch) and will do the same thing.
You could also put you second gateway outside the first gateway. Since it'll wait until SVR completes, then you could just wait until you get the response from SVR before going in the next gateway in your process.
Alternatively, if it still doesn't make sense to you, you could leverage the Task Complete event, and have a separate process that just send acknowledgments upon task completion, and not use a gateway at all.
Anyways, let me know.
Jasmin
Total Likes
i want to use the gateway only....
In my case acknowledgments means notification. if second and third
branches have
not even acted the flow should not stop we are just notifying no need
of their response.
if SVR replied it should go to INITIATOR no need to wait until second and
third branches completes.
in the same case in gateway 2 even if A3, and A4 are not responding the flow
should not stop.
because Initiator Re-submitted it should go to gate way1....
how should i approach it
Total Likes
Are you excepting the notifications to come back? I always assumed you would send the notifications and then you're done. That's why in my example A1 and A2 would be completed almost instantly and then would go to the end of the gateway and wait until SVR completes. SVR would be the one that decides when the gateway completes.
Is that a valid assumption? Do you want to to have the possibility to wait for a response back from those notifications? How would you send the notifications?
Jasmin
Total Likes
Yes your assumption is correct.....
notification should not come back...... but the braches of A1 and A2 will
be in running state until user not click complete button in the form .
even the same case with gateway2 ... i want only the action done by
initiator
but if we use AND gateway all the branches should be complete right?
is there a way that once we send the notification to the user we can we can
make the branch status complete even if A1 or A2 dont open the form and
click complete.
at last end of the gateway1 i should know what the initiator done if he
accepts no problem ...
if he resubmit it should go to start of the gateway....
please let me know how can i approach it.....
Total Likes
I get it now!!!!!
I didn't realize your A1..A4 were also user steps (tasks). I though the notifications were simply an email sent to a user.
I've built something very similar a while ago.
The way I had to do it was to leverage the TaskCompleted event.
I built a separate process and used the TaskCompleted StartPoint so that it receives all Task Completed events. Then I had a filter to see from which step the event was coming from (for example SVR). If it came from SVR and the action was "Approved", then I called a custom component that would terminate the other tasks within the same gateway.
The tricky part was to figure out all tasks within a gateway. I had to do a database call to get the infromaiton, which of course is not a supported. But it worked.
Jasmin
Total Likes
thanks for your suggestion .... i will try out and update you....
Total Likes
I just tough of something else.
We have this solution accelerator called Manage Review and Approval (MRA). This solution accelerator allows you to do sequential and parallel review and make users optional in a parallel review.
You may not need all of its functionality, but you could look at the processes and use them as a starting point.
You can find it at http://www.adobe.com/devnet/livecycle/solution_accelerators.html
Jasmin
Total Likes
