1 Reply Latest reply on Jan 13, 2009 9:56 PM by kglad
    loading movieclips to stage?
    shintashi
      I have two movieclips in my library with linkage listed "meiosis1" and "meiosis2".
      this:
      if(Key.isDown(Key.SHIFT)){
      this.attachMovie("meiosis1", "kyro2", 1, {_x: 128, _y: 128});
      this.attachMovie("meiosis2", "kyro3", 1, {_x: 128, _y: 128});
      doesn't work.
      I also tried _root.attachMovie, but no success.
        • 1. Re: loading movieclips to stage?
          kglad Adobe Community Professional & MVP
          meiosis2 should attach when your use _root.attachMovie().
          they both won't attach because you're using the same depth and "this" may reference something other than a timeline because i'm sure that code has been extracted from a handler or function.
          well, maybe not. if that code is attached to a timeline then it will fail because it's not in a Key listener and it can't be in a loop or you're going to have problems repeatedly attaching the 2nd movieclip.
