SOLVED
What is initial value of an empty drop-down?
Avatar
Level 3
I have written a script to populate the items in a drop-down list but only if there is no entry already existing.
The problem I have is recognizing that the list is empty. I have tried to test for null (if dropdown.isNull = true) and testing the
rawValue = "" and a bunch of other things with no good result.
I'm sure this is easy but apparently not for me.
Thanks for the help!
1 Accepted Solution
Avatar
Correct answer by
Former Community Member
Those commands are testing the value that is selected by the user. As they have not selected anything yet they will not have a value.
The command:
DropDownList1.items.nodes.length
Will give you the number of items in the DDlist. It is 1 based. Note that it will not count any items that were added to the dropdown by the user.
Paul
Avatar
Correct answer by
The command:
Paul
Avatar
Level 3
Both are correct! Thanks for the assistance!
The following has evaluated to null or missing: ==> liqladmin("SELECT id, value FROM metrics WHERE id = 'net_accepted_solutions' and user.id = '${acceptedAnswer.author.id}'").data.items [in template "analytics-container" at line 83, column 41] ---- Tip: It's the step after the last dot that caused this error, not those before it. ---- Tip: If the failing expression is known to be legally refer to something that's sometimes null or missing, either specify a default value like myOptionalVar!myDefault, or use <#if myOptionalVar??>when-present<#else>when-missing. (These only cover the last step of the expression; to cover the whole expression, use parenthesis: (myOptionalVar.foo)!myDefault, (myOptionalVar.foo)?? ---- ---- FTL stack trace ("~" means nesting-related): - Failed at: #assign answerAuthorNetSolutions = li... [in template "analytics-container" at line 83, column 5] ----
