1. Re: DVD starts without showing menu first...
Stan Jones Apr 14, 2010 8:25 AM (in response to Xoomtell)What do you have set as "first play"?
Just in case it matters: what version (CS3; CS4?); what platform/os (XP, W7, Mac etc).
2. Re: DVD starts without showing menu first...
Bill Hunt Apr 14, 2010 2:52 PM (in response to Xoomtell)Morten,
Along with Stanley's questions, what brand of blank media did you use, and at what speed did you burn that disc?
Good luck,
Hunt
3. Re: DVD starts without showing menu first...
Moxtelling Apr 15, 2010 3:45 AM (in response to Bill Hunt)Hi
Thx for your answers.
I have set my menu as first play...isn´t that correct?
I have the following setup:
Operating System: MS Windows 7 64-bit
CPU: Intel Core i7 920 @ 2.67GHz
RAM: 12.0GB Triple-Channel DDR3 @ 532MHz 7-7-7-20
Motherboard: Gigabyte Technology Co., Ltd. EX58-UD4 (Socket 1366)
Graphics: NVIDIA GeForce GTX 260
Hard Drives: 2 X 1500GB Seagate ST31500341AS ATA Device (IDE)Optical Drives: PIONEER DVD-RW DVR-216D ATA Device
Audio: M-Audio FW 410I run CS4.
4. Re: DVD starts without showing menu first...
Moxtelling Apr 15, 2010 3:48 AM (in response to Bill Hunt)Oh - sorry - and medium is:
Verbatim 4.7GB 16x certified DVD+
I build it as image first and the burn to disk with 10-12x speed.
5. Re: DVD starts without showing menu first...
Stan Jones Apr 15, 2010 9:51 AM (in response to Moxtelling)Yes, menu first play is correct.
I would burn to a folder and play from the folder version on the computer. If that is okay, it points to disk issues. (Or play your iso on the computer.)
Bill will give you some more detail on the disk issues; try doing a burn at the slowest speed your disks allow. Generally, I like DVD+RW for testing, but if you don't have any....
6. Re: DVD starts without showing menu first...
Bill Hunt Apr 15, 2010 12:25 PM (in response to Stan Jones)Well, the Verbatim blanks are as good as it gets.
Only thing that I wonder about is the +R. Nowadays, the type, -R vs +R, as not the issue that they once were. Still, if one has an older set-top player, that could cause some playability issues.
If Play First is working in the ISO, the preview, and from a VIDEO_TS folder on the HDD, but not in a set-top player, I'd definitely check the disc out in another set-top player.
Good luck,
Hunt
