1. Re: <flexunit:TestRunnerBase >problem
mlabriola Mar 17, 2010 8:26 AM (in response to ursaditya)Change the MXML in your file to this instead
<flexUnit:TestRunnerBase id="uiListener"
width="100%" height="100%" />Just TestRunnerBase versus BaseTestRunner. Just as an FYI, what is really happening here is that we are instantiating the UI which was originally written for FlexUnit .9. It is then wrapper in our UIListener, which you are doing correctly, to adapt it. Then it is used as a listener.
In the next release or so of FlexUnit this will become easier as this UI is phased out in favor of a simpler model.
Mike
2. Re: <flexunit:TestRunnerBase >problem
ursaditya Mar 17, 2010 7:13 PM (in response to mlabriola)Thanks Mike it is working absolutely fine
with regards
aditya
3. Re: <flexunit:TestRunnerBase >problem
showboat44 Mar 18, 2010 2:01 AM (in response to ursaditya)I still have the same problem. "Could not resolve <...TestRunnerBase>. Downloaded the FlexUnit4TurnkeyRC1, running it through FlashDevelop unsing flex framework 4..0.0. Some help please.
4. Re: <flexunit:TestRunnerBase >problem
mlabriola Mar 19, 2010 8:37 PM (in response to showboat44)Post your code so we can help you.
I am guessing that your namespace on the top of the file either doesn't point to the correct one for the library or isn't matching the tag but I won't know until I see it.
Mike
5. Re: <flexunit:TestRunnerBase >problem
showboat44 Mar 22, 2010 12:33 AM (in response to mlabriola)I have downloaded the FlexUnit Turnkey RC1 and using it as is, without any changes. I run into a lot of problems, mainly the one stated above. However, I have been able to get it to compile occationally, but then i get another problem. Identifier uiListener is used more than once. I change the name of it and it compiles again, but the problem returns. Please shed some light.
6. Regarding FlexPMD
ursaditya Mar 22, 2010 3:52 AM (in response to mlabriola)Hi Mike ,
I need some help on using flexPMD in "Flex Builder 3" without using maven and ant .. and also how to use and write rules in flexPMD ...
with regards
aditya
7. Re: Regarding FlexPMD
mlabriola Apr 15, 2010 8:50 AM (in response to ursaditya)Sorry, but I don't know enough about PMD to help you
10. Re: <flexunit:TestRunnerBase >problem
Roy.P. Nov 17, 2010 2:23 PM (in response to mlabriola)I am also getting this same error. Using FlexBuilder3 (3.4.1 SDK).
Here is my code:
<?xml version="1.0" encoding="utf-8"?>
<mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml"
xmlns:adobe="http://www.adobe.com/2009/flexUnitUIRunner"
layout="absolute" creationComplete="init()">
<mx:Script>
<![CDATA[
import flexUnitTests.TestSuite;
import org.flexunit.runner.FlexUnitCore;
import org.flexunit.listeners.UIListener;private var core:FlexUnitCore;
public function init():void {
core = new FlexUnitCore();
core.addListener(new UIListener(uiListener));
core.run(TestSuite.ampTestSuite);
</mx:Script>
<adobe:TestRunnerBase id="uiListener" width="100%" height="100%" />
</mx:WindowedApplication>This is the error: Could not resolve <adobe:TestRunnerBase> to a component implementation.
Roy P.
11. Re: <flexunit:TestRunnerBase >problem
PhantomGAD Nov 28, 2010 6:13 PM (in response to ursaditya)to ursaditya :
Compiler can't resolve namespace
you need change it from "http://www.adobe.com/2009/flexUnitUIRunner" to "org.flexunit.flexui.*"
eg find in the begining of your code
xmlns:flexunit="http://www.adobe.com/2009/flexUnitUIRunner"
and replece with
xmlns:flexUnitUIRunner="org.flexunit.flexui.*"
to Michael Labriola;
if I am correct you Adobe Evangelist and write article flexUnit4 in 360 seconds - shame on you that you can't resolve this problem.
But thanks anyway for article!
I really don't like flash/flex documentation since Adobe bye macromedia.
12. Re: <flexunit:TestRunnerBase >problem
mlabriola Nov 28, 2010 6:17 PM (in response to PhantomGAD)First, if you note above I did suggest a namespace problem. Second, if you are using this namespace, what it actually means is that you somehow have a library compiled without the proper namespace or things would have worked as expected. Third, I didn't just write the article, I wrote all of FlexUnit.
Mike
13. Re: <flexunit:TestRunnerBase >problem
mlabriola Nov 28, 2010 6:20 PM (in response to mlabriola)Also, FlexUnit isn't an Adobe project. It is a community project run and documented purely by volunteers, so please feel free to volunteer to help fix any documentation you feel lacking.
Also, as was noted on some of the other posts with the same question, you can take a look here for some additional knowledge base information:
Mike
