I keep getting the message that
Your project file is corrupt and cannot be opened.
Try deleting this file and reopening the project.
I've been reading though some of the pervious solutions and none of them seem to be working. Is there anything else I can try?
Things I've tried
1) moving the .xpj file elsewhere and opening the .hhp file, --> I get the warning There is already a Project file for this project. Would you like to use the XPJ father thand the HHP file? Is there another way to open a project if you delete the .xpj file?
2) renaming the .cpd file and opening the .xpj file --> RH8 open and goes into "Loading TOC" but then crashes
Is there anythign else I can try?
Each forum has a Sticky Topic, Before You Post. http://forums.adobe.com/thread/467760
Please start each thread with the edition and version of RoboHelp that you are using.
There is an article on my site about opening RoboHelp projects. The XPJ is not where I would have started. Did you backup your project before you started trying to deal with this or do you have a recent backup? If so try again following these steps.
http://www.grainge.org/pages/authoring/opening/opening_projects.htm
