Hello - I just installed CFBuilder. I can add my localhost server (JRUN) and can start and stop it. But when I use te RDS viewer it fails almost 100 percent of the time with a "Read timed out" error. In three days of trying I was able to see the tables in my databases twice - all the other times it times out. Any deas?
Were you able to fix this issue. I just installed CF9 with CF Builder and the exact same things is happening. Win 7 64-bit
My issue turned out that I did not have the DNS configured correctly. We use SQL Server on a non-standard port. Once I had the port correct everything worked.
Thanks, I just restarted IIS and it is working, with my fingers crossed.
