1 Reply Latest reply: Apr 19, 2010 3:08 AM by Kh7 RSS
    Problem with AMFPHP
    Kh7 Community Member
      I try to load function from PHP using AMFPHP in Flash. But Flash returns an error:
      Error #2044: Unhandled NetStatusEvent:. level=error, code=NetConnection.Call.Failed
      AMFPHP works correctly and I tested my PHP service in it -- it's OK. What can cause the problem?
      Here is my code:
      import flash.net.*;
      var gw:NetConnection = new NetConnection();
      gw.connect("http://localhost/amfphp/gateway.php");
      var responder:Responder = new Responder(onResult, onFault);
      function onResult(respond:Object)
      { trace(respond); }
      function onFault(error:Object) {
           for (var i in error)
           { trace(error[i]); }
      gw.call("Calc.add", responder, 2, 3);
      I work on localhost.
