Print multiple pages on sheet
Guest
Apr 15, 2010 Apr 15, 2010
I am using Adobe Reader and would like to print two copies of the same document on the same sheet. It doesn't seem to allow me to do that no matter what settings I put in the print dialog box or the printer driver. I have told it "2 up" and the paper size is 18 x 12, the document itself is 8.5 x 11 so there should be plenty of room. Can someone point me in the right direction?
  Mark
139.6K
Deleted User
Apr 19, 2010 Apr 19, 2010
As per my understanding of your problem, you have a one page PDF and you need to print 100 copies of the same page with page scaling of Multiple Pages per sheet.
If this is the problem then this can't be achieved using combination of Copies and Multiple Pages per sheet feature.
Adobe Employee ,
Hi AremisBree,
Try the following steps:
1. Launch the print dialog.
2. Select the Page scaling as "Multiple Pages Per sheet"
3. Choose "Custom" in "Pages Per sheet" and write 1 by 2 as the value.
I hope this will resolve the issue at your end.
-Shilpi
Guest
Apr 16, 2010 Apr 16, 2010
Thanks Shilpi,
It didn't work. The preview still shows copy 1 on the far left side of the page with plenty of room on the right for copy 2 but even when I put to print 100 copies, it doesn't put two on a page. I guess the multiple pages per sheet only works with unique pages?
  Mark
Adobe Employee ,
Could you please provide us the following information:
1. Which version of Adobe Reader are you using?
2. Which printer driver are you using?
3. Which Wondows version are you using (XP/Vista/Win7)?
4. Please upload the test file here.
-Shilpi
-Shilpi
Can't be done any more. They've taken away all but image uploads.
You'll need to upload the file to a web space and then post the link here.
Guest
It's Adobe Reader 9.3.1
Printer is a Xante Ilumina Digital Press with the lastest PCL driver.
Windows 7
File is stored here: http://www.box.net/shared/m3cul6ek7h
  Mark
Guest
- Make a copy of the file.
- With Adobe Acrobat combine the two files to a new document.
- Print this new document using "2 up".
Guest
Thanks to everyone who helped. Ultimately, it turns out to be something I apparently can't do through my print driver (which doesn't make sense.) I unfortunately do not have Adobe Acrobat, though it may turn out to be necessary to get it in the near future.
Thanks again,
  Mark
Apr 21, 2011 Apr 21, 2011
I understand the workaround, but hate having to do it. In case anyone from Adobe is reading, why oh why must I used a workaround for what should be a basic feature? Not asking for complicated plug-in level imposing software, just take the excellent work you've done with multiple-page printing on a single sheet, and make it work with a single page. Please!
Apr 22, 2011 Apr 22, 2011
... why oh why must I used a workaround for what should be a basic feature?
That isn't a basic feature. It is a special requirement.
Jul 01, 2011 Jul 01, 2011
Were you able to resolve this problem yet?
I was having the same problem a little while ago today but I finally figured it out.
In order to print two pages (or in my case, three) to a sheet, two (three) pages need to be available in the document file, even if the two (three) pages per sheet are the same exact page.
So I went into Acrobat with my document file (Adobe Acrobat 8 Professional, version 8.3.0, is what I'm using) and inserted extra pages using the same file (under the Document tab on the menu bar) and then proceeded to try printing again. VOILA! The print preview was finally showing me three pages to one sheet and when I printed it out, SUCCESS!
I realize that you asked your question a little more than a year ago, but I figured I'd respond to it anyway (even though I now notice that Bernd Alheit pretty much responded with the same thing). Hope it helps!
Aug 16, 2018 Aug 16, 2018
I know this is a very old posting, but you just solved my printing problem! Thank you.
Participant ,
Apr 14, 2022 Apr 14, 2022
Zadijm,
Thank you for posting the resolution to this frustrating mystery in Adobe Reader!  It is hard to understand why Adobe doesn't clarify their features with some sort of context help when they see people are frustrated by a feature.
The problem here is that many users, like ourselves, inadvertently perceive this as a DUPLICATION or COPY feature for a single page, which it is NOT.  The MULTIPLE feature does not duplicate pages, rather it groups subsets of pre-existing pages in the document and prints each subset of multiple pages on single sheets until the complete document is printed.  Which actually makes good sense.
Interestingly, in the case of a single sheet document, they could very easily provide an extremely useful DUPLICATE checkbox or option for the MULTIPLE page section.  This option would allow a user to quickly duplicate the same page multiple times on a single sheet.
Thank you again for a very enlightening response that saved us a whole lot of frustration!
Nov 19, 2023 Nov 19, 2023
worked for me, thanks.
Sep 22, 2013 Sep 22, 2013
I know this is over three years old, but in case anyone else needs this, I figured out how to do it.
After setting the page scaling to "Multiple pages per sheet" all you have to do is repeat the page in the "pages" field. For instance, If I have a document that prints front and back and I want it to print 3 up, I would set the "pages per sheet" to 1 by 3 and then for the page range, I would enter 1,1,1,2,2,2. This tells Acrobat to print page 1 three times, then page 2 three times. Since it's set to 1 by 3, it will arrange 3 iterations to a sheet.
Hope that can still help someone here.
Guest
Mar 04, 2014 Mar 04, 2014
This does the trick, thank you very much for the great idea - but only if the pdf has more than one page.
When there is only one page (as in the original question and my case) the pdf the printing dialog "smartly" disables the radio buttons "current page" and especially "pages" with the field to enter page numbers (eg "1,1,1,1" when printing 4 similar pages on one sheet).
Aug 27, 2017 Aug 27, 2017
Genius, it's been annoying me for a while! Cheers
Participant ,
Thank you for the brilliant solution!  It adds some incredible flexibility to our printing needs and eliminated a load of frustration.  However, as others have stated, why in the world does Adobe disable the PAGES TO PRINT range feature with a single page document?  Especially when the feature supports duplicating single pages in this field.  This is just another unnecessary frustration for users.
Oct 15, 2016 Oct 15, 2016
In case your PDF has only 1 page. Print 2 copies of the page to a new PDF file.
Then open the new file and use ElWarboGrande​​ solution (use pages numbers: 1,1,1,1,1,1,1,1)
Participant ,
Another brilliant work around for those without an expensive PDF editor, thank you for sharing!
Note this will not work if the file only has one page, though, as Reader automatically disables the Pages options in the Print dialog then.
Jan 23, 2022 Jan 23, 2022
Whoever answered this is a genius.  I just spent two hours trying to do the same thing, print multiple invitations for my kid's birthday party on one sheet, and this worked beautifully!  Thank you deleted user!!!
Jul 19, 2022 Jul 19, 2022
Was googling this and found this thread, it still didn't work for me, but then a lovely person gave me this link to try something different and I prefer this option. I feel gives me more flexibility, hope it helps you too.... 🙂
https://www.youtube.com/watch?v=KVfc7uWD0Z0
Mar 09, 2023 Mar 09, 2023
This thread helped me, 13 years later.  You'd think they would have upgraded the Printer Options by now, but NOPE.
Based on other responses, I printed my document to a PDF and made 4 copies. This gave me a PDF with 4 pages with the same thing on each page.  Then I printed that PDF with "Multiple" selected and 2x2 for Pages per sheet, putting 4 to a single page.
