Making the contents of the <title> tag conditional
Guest
Apr 19, 2010 Apr 19, 2010
(RH HTML, version 8.0.2.208.)
Hi all,
Is there a way of making the contents of the <title> tag conditional? One of my topics needs to have a different title according to the chm it goes into (designer chm or end user chm). Search results are based on the contents of the <title> tag, not of <h1>, so the contents of the <title> tags do need to be specific.
I tried applying conditional tags inside the code manually (I copied <?rh-cbt_start condition="Designer" ?>, etc), but it just doesn't work (both versions of the title show).
Then I created 2 different html files, each with the correct <title>, and inserted the contents of the topic as a snippet. That worked OK. But now I have an image map in another topic that refers to my double-file topic (and this image map appears in both versions of the chm as well)! The only way to make things work is to have 2 versions of the image map, each with the correct link.
I thought the idea of single sourcing was to make things simpler and to save time... Did I miss something? Does anyone have any suggestions?
Thanks, C.
459
Hi there
Looks like you have done your homework!
Indeed it would be a nice feature to be able to conditionalize the Title attribute. Please take a moment and suggest it via the Wish Form.
What I might suggest is that you create a Related Topics link that points to each of the desired topics. My hope here is that when one or the other topics is removed by conditionalizing, it will leave behind a single link. Then instead of seeing a popup chooser, the link just works to open the single topic.
Give that a go and see how well it may work.
Cheers... Rick
Helpful and Handy Links
RoboHelp Wish Form/Bug Reporting Form
Begin learning RoboHelp HTML 7 or 8 within the day - $24.95!
Adobe Certified RoboHelp HTML Training
SorcerStone Blog
RoboHelp eBooks
This is an outstanding feature request so do submit your request to up the chances. It's needed for people who work with multiple languages too.
@petergrainge
Guest
Apr 20, 2010 Apr 20, 2010
Thanks to you both for your responses. I have submitted a feature request.
Rick, were you suggesting to insert the Related topics button on top of the image map?
C.
Guest
Mmm... as far as the image map is concerned, it seems that the conditional expression I tried using yesterday to no avail is now working (I made the <area/> tag conditional). I changed nothing in the meantime, all I did was close and reopen the project. No accounting for RoboHelp behaviour...
(Of course, this changes nothing to the conditional <title> tag issue.)
RoboHelp Documentation
Download Adobe RoboHelp
