As my handle suggests I'm really a newbie.
From my research I know that the filename of the pdf (which shows in the form properties) is somehow accessible using xfa.resolveNode but I don't know how to ask for it. ie. I don't know the reference to use for request to filename.
just wondering if anyone could quickly point me in the right direction.
also is there a good reference for all the objects in the DOM and how to get at them?
George
If you add the file name to the title in the form properties as follows:
you can access the title using xfa.host.title.
Steve
Total Likes
Thanks for the suggestion Steve. Unfortunately I really need the filename
field since the form is a "signable" form which seems to have the added
functionality(somewhat useful) of saving itself to another file when it gets
"signed" . What I then want to do is grab the file it saved itself as and
send an email to the next approver with the filename of the where it saved
itself on our corporate CMS system(RDIMS).
Also, if you know of where I can find more info on all objects in the DOM
and how to reference them...I would be very grateful.
Thanks again
George
Total Likes
To get to the filename of the file that is loaded use this command:
event.target.documentFilename
To get info about the different objects that are available look at the help in designer and specifically the scripting reference.
Paul
Total Likes
Thanks a lot Paul
Total Likes
Hey Paul,
see attached..
there doesn't seem to be a "documentFilename" attrib to target?
Total Likes
The command is actually an Acroform command. The event.target will get you to the doc object in acrobat. The object assist is for XFA only so it will not show up there ....but it will still work.
paul
Total Likes
ahhhhh
things are starting to defog...thanks muchly...have a good weekend
Total Likes
Sorry the commmand is documentFileName not documentFilename
paul
sorry Paul to keep bugging you...my day is not going well obviously....
I did everything you told me and please see attached....
it seems that the filename your command picks up is some temp filename and
not the one in the form properties.
any ideas?
Thanks again
Total Likes
You are running inside of the Preview. The PDF gets created in a temp folder with a temp file name and that is what is being reported. If you save the file out and use it outside of Preview it will report the filename as you know it.
paul
Total Likes
wow...you're so smart man !!!
thx
Total Likes
Hi Paul,
I wish I could find this stuff on my own..but don't know where to look for
the function calls.
anyway..
2 probs:
1-I want to do something similar to
http://www.windjack.com/PDFSamples/DynamicEmail_AcroForm.pdf which works but
my version
(see attached) doesn't.. But the attached code for "Submit for Approval"
button seems similar to me but doesn't work. I think only difference is that
the example is an acrobat form and the latter is in livecycle....any ideas?
2-How do I access the variables set in the form properties "variables" tab
since Ideally I'd like the users to set these depending on who the form has
to be approved by? Again...I'd love to look these up myself but am having
problems finding the object references. any help is appreciated.
Thanks again.
George
Total Likes
There is no attachment can you email me the form instead.
To get at system variables you woudl use variableName.value. How are you going to get the user to set them (they are set at Design time).....maybe you shouldl describe what you are trying to accomplish and I can suggest a way.
Paul
Total Likes
Hi Paul,
here is the msg again. Hopefully the attachment comes through.
see comments inline
thx again
mailto:LiveCycle8@gmail.com
>>I don't know if they are the "system variables" ..the one's I'm talking
about are those under form properties/variables tab in the livecycle file
menu.--I would set them on behalf of the "owner" of the form.
suggest a way.
>>see form attached..what I'm trying to do is create a routable form.
ultimately fully automatic where, once the first signature has been set it
routes to the next etc.
But I've found that our management wants to save a copy in our CMS system
(RDIMS) after every signoff. This actually works at this point since the
signing forces a save. So....therefore I just want to "inform" the next guy
inline to sign it off (hence the need to read the emails of next in line
from form variables).
Thanks Paul
Total Likes
It did ...I replied to the email
Paul
Total Likes
Hi Paul,
just sent something to your livecycle8@gmail.com acct.
hope that you might give me a hand
Thx
George
Total Likes
