Hi again
Well, I would think the "How did they get there" is pretty
simply answered. You copied them when you copied the project. Odds
are that you just wholesale copied the folder. And that's perfectly
normal! I'd be doing the same thing. But what remains a mystery is
why they still existed after you cleared the content and generated
with new. It's a mystery because I thought that among the first
steps RoboHelp took when generating was to first clear the output
folder of content. It would appear this isn't happening for some
reason.
You should be able to manually delete them. That's what I'd
suggest. Then generate again and see if they are still gone. They
likely will be. But if not, you have further sleuthing to do to
determine where they are coming from.
Once you are certain you have the correct set of source
files, your next job will be to delete the inappropriate files from
the server location where you published. This is because the
publishing process only copies content. It will never delete
content on a server.
Cheers... Rick
