Hi Everyone,
I was just wondering if there is an issue with the way I set things up, but when I generate images (jpg, gif, tiff, etc) through a Livecycle Process, the resulting pdf appears to be in pdf/a format. I am not able to do things such as add sticky notes to the pdf. I am using pdf generator on livecycle es2 setup in a CentOS 5 x64 environment.
I also have access to a windows machine, with the identical Livecycle Process, when generating a pdf from an image using the same process, I do not have the same problem. I am able to add sticky notes to the pdf without an issue.
I compared the differences in settings between the two machines and the are identical. Would anyone know why this is happening?
Total Likes
