Greetings,
In a generated project, created in the RH8, when the user hovers over an image, the file name displays. I checked the image properties and Screen Tip text field is empty.
How can I prevent the image file name from displaying in the generated project?
Hi there
When you examine the generated code what do you see? Is there a Title attribute or an Alt attribute? You didn't say what the output type was. Is it WebHelp? If so, did you enable Section 508 options when you generated? (Part of being Section 508 compliant is giving images corresponding names)
Cheers... Rick
Helpful and Handy Links RoboHelp Wish Form/Bug Reporting Form Begin learning RoboHelp HTML 7 or 8 within the day - $24.95! |
Hi there
Cheers... Rick
Hello Rick,
The output is WebHelp, and the 508 Box is not checked. The ALT tags are the culprit.
Thanks for your help
