My group uses powerpoint extensively to build course notes. We have an internally built source management system that enables us to check-out PPTs from a server location, create a local copy, use custom templates for editing, then check the file back into the server. Now we have created numerous Captivate projects that make use of these slides. We have imported the slides from the local copy, and then used the linking feature in Captivate. We thought this would be an advantage because it allows us to edit the slides directly from Captivate, but in practice, it seems like it just makes things more complicated when we're making updates because our source management system wants to control these slides and move them around on the server. When we check them in, it removes the local copy. Now we are ending up with multiple versions and having to keep track of what Captivate is linked to and where the server copy is. We are encountering lots of funny behavior in Captivate and the source management system when we are editing slides, so we are thinking about moving to embedding instead.
My questions:
Thanks for your help!
Hi there
As I understand it, here's the difference.
Perhaps you have a Powerful Pointing guru named Pat. Pat is responsible for ALL PPT presos in the company. Pat likes the presos to be stored on the company server where everyone sees them on drive letter Y.
Pat is constantly making updates to the PPT presos. In this case it makes sense to LINK. That way Pat can make all the changes that are needed at any given time.
You, the Captivate developer would then need to be aware that Pat changed the preso. Then you could just update in Captivate to pull in Pat's changes.
Linking Pros:
Pat may change presos whenever s/he desires
Centrally accessed presos
Linking Cons:
If you choose to take the Captivate file home with you to work on it, you will not be able to update or make edits to the PPT, because it's on the LAN
Embedding Pros:
Whomever has the CP file also has the PPT file because it's copied to the innards of the CP file
Embedding Cons:
The CP file will swell by the size of the PPT file.
No longer centrally accessed PPT.
Hopefully this helps... Rick
Helpful and Handy Links Captivate Wish Form/Bug Reporting Form |
Thanks, this explanation is helpful, and it is how I would expect this feature to work. However, working this way doesn't seem to be very practical if you follow the tips for working with PowerPoint that I found in help:
PowerPoint tips: Follow these guidelines when you work with Adobe Captivate and PowerPoint:
Followign the guidelines in help, it appears they expect you to link to PowerPoint files that are on a local drive. That isn't very practical when you're doing shared development, like we are and the way you describe in your example.
I guess I'm wondering which method people prefer to use in real life (linked or embedded). Linked doesn't seem as useful when you take the restrictions into account.
Hello again
Just some thoughts here.
Avoid parallel edits.
For example, suppose you edit a linked PowerPoint file within Adobe Captivate and a copy of it outside the application simultaneously. In such cases, the results are unpredictable.
Well I'd have to say that parallel edits are just simply frowned upon. While it's certainly a tip that applies to PowerPoint, it really applies to nearly anything as you often end up with a "which version is the correct version" situation. My vote goes for making all primary content edits in PowerPoint and updating Captivate as a result. And really, that's the whole reason for linking.
Thanks Rick. These are all very good observations. I'm glad to see that you agree
that the network drive restriction does not seem reasonable. When I see something like that in the help, it makes me worry that they must have encountered some bugs in testing so they are trying to cover themselves. It does seem to thwart they whole idea of having the link feature. I wish the doc had a bit more information about the internals of what is happening between Captivate and Powerpoint so problems would be easier to debug.
Regarding the 'live' connection to PowerPoint, that's something I've wondered about too. I have seen some messages within Captivate that prompt me to update my slides, but it is hard for me to figure why the message shows up and what prompts it. It seems kind of random. It may be because I have sometimes edited slides throught the Captivate interface, while other times doing the edit through PowerPoint. I've never done it at the same time (had the presentation open on Captivate and in PowerPoint for editing), but I have gone back and forth at times. I think I'm going to just drop the idea of editing through Captivate.
So a reasonable approach to try might be:
I'm going to try some testing to see how things behave working in this direction. I managed to get a Captivate project so hosed up the other day it wouldn't run when published, but I think it was after editing through Captivate instead of PowerPoint.
