Hello,
I am rather new to flash builder and currently having problem to cast a string to an image in my function. Here's the details
1) I have declared few image holders as below:
<mx:Image id="img0" x="40" y="80" width="250" height="550" mouseDown="img0_mouseDownHandler(event)"/>
<mx:Image id="img1" x="298" y="80" width="240" height="270" mouseDown="img1_mouseDownHandler(event)"/>
2) Through Http Service I am then getting the rss feed of xml in my result handler function.
Also, in the same function I am building xmlList for my photo locations in the XML
photoXMLList = tXML.entry.link.(@rel == 'enclosure').@href;
3) After this I am looping through the index to traverse xm llist and place the photo into image place holders based on the current index of traversal:
//declaration
var strIndx:String; // string holds dynamically generated image id
var index: int;
var image:Image;
//initialize index
image = new Image();
index=0;
img= "img";
//loop through index and ge
for (n=index; n <=index+4;n++)
strIndx = img +(index.toString());// make the strIndx to image id of current value e.g. first value would be img0 here
if (tXML.entry[index].category.@term == "550")
if ( index == 0 )
Alert.show(strIndx); // shows img0
// problem here...not able to cast the indx containing string value of image id i.e. img0
// into image component, more importantly image id
image=mx.controls.Image(strIndx);
image.source = photoXMLList[index];
As explained in above code I am not able cast the string value of image id's (strIndex in above case) to actual Image value. I have tried to do that using casting to image variable but flex is not conevrting it for some reasons.
I would Highly appreciate prompt help on this!
Akshay
hi,
i'm having a little trouble trying to work out what you are trying to do, but if I have an'array' of images then
for (var i:Number=0; i < data.length; i++)
var img:Image= new Image();
img.id = "img"+String(i);
img.addEventListener(MouseEvent.CLICK,myImageClicked);
img.source=data.imagename;
now I have 10 images that have ids from img0 to img9, an event that is called if they are clicked each image is loaded from a collection called data which contains the name of the image.
David.
Thanks David,
That sounds exactly what I wanted. Sorry for posting this question on multiple forum. I am using flash builder now so thought of posting it on this forum too.
Based on you reply I amended my previous code as below:
image.id = img +String(index);
and then load the source
but still no luck . but if I would put the id explicitly as below
img0.source = photoXMLList[index]; // id of first max: Image
it just works fine ......not sure what is wrong here
Akshay
hi,
When loading images it's not quite as simple as sample I gave, I was just trying to get a feel for what you where doing,
I have an example of loading multiple images by their bytedata into an array then use that for display, It is based on local files but the principle is the similar. Rather than using the filereference loader you would use a url loader.
http://gumbo.flashhub.net/pagedrop/
David
Thanks David for your patient and helpful replies so far..
Here's the full code.. Please let me know what you think
Akshay
------------------------------------------------------ Code--------------------------------------------------------------------------- --------
<?xml version="1.0" encoding="utf-8"?>
<s:Application xmlns:fx="http://ns.adobe.com/mxml/2009"
xmlns:s="library://ns.adobe.com/flex/spark"
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="1250" creationComplete="photoService_T.send(),photoService_O.send()" minHeight="600" backgroundColor="black">
<fx:Style source="Flickr_Test.css"/>
<fx:Script>
<![CDATA[
import mx.collections.ArrayCollection;
import mx.controls.Alert;
import mx.controls.Image;
import mx.effects.Resize;
import mx.events.FlexEvent;
import mx.events.ItemClickEvent;
import mx.events.ListEvent;
import mx.events.MoveEvent;
import mx.events.ResizeEvent;
import mx.managers.PopUpManager;
import mx.rpc.events.FaultEvent;
import mx.rpc.events.ResultEvent;
import mx.utils.object_proxy;
[Bindable]
public var photoXMLList:XMLList;
private var img:Image;
private var image:Image;
public var photoXMLList_new:XMLList;
//private var img_new:Image;
var nsDefault:Namespace = new Namespace("http://www.w3.org/2005/Atom");
private function photoResultHandler_T(re:ResultEvent):void {
default xml namespace = nsDefault;
var img:String;
var indx: String;
var booltest:Boolean;
img="img";
var tXML:XML = re.result as XML;
var n:int;
for (n=0; n <=5;n++)
image.id = img +String(n);
Alert.show(image.id.toString());
if (tXML.entry
if ( n == 0 )
private function photoFaultHandler_T(fe:FaultEvent):void {
Alert.show(fe.fault.message);
protected function photoResultHandler_O(rew:ResultEvent):void
// TODO Auto-generated method stub
var tXML_new:XML = rew.result as XML;
photoXMLList_new = tXML_new.entry.link.(@rel == 'enclosure').@href;
protected function photoFaultHandler_O(fen:FaultEvent):void
Alert.show(fen.fault.message);
</fx:Script>
<fx:Declarations>
<s:HTTPService id="photoService_T" url="http://api.flickr.com/services/feeds/photoset.gne?set=72157623742603753&nsid =48951865@N07" resultFormat="e4x" result="photoResultHandler_T(event);" fault="photoFaultHandler_T(event);"/>
<s:HTTPService id="photoService_O" url="http://api.flickr.com/services/feeds/photoset.gne?set=72157623867029406&nsid =48951865@N07" resultFormat="e4x" result="photoResultHandler_O(event);" fault="photoFaultHandler_O(event);"/>
<mx:WipeDown id="image_addedEffect" startDelay="50"></mx:WipeDown>
<mx:Parallel id="image_removedEffect">
<mx:Zoom />
<mx:Fade />
</mx:Parallel>
</fx:Declarations>
<mx:Image id="img0" x="40" y="80" width="250" height="550" />
<mx:Image id="img1" x="974" y="80" width="250" height="550" mouseDown="img6_mouseDownHandler(event)"/>
</s:Application>
