2 Replies Latest reply on Apr 23, 2010 9:26 AM by dakasadakasadaka
    SpriteVisualElement in for loop
    dakasadakasadaka Level 1
      Ok I have more then one camera and I need to place it into SpriteVisualElement.
      I trying ike this:
      public function broadCastMeNow(event:Event):void
          //var camId = comments.selectedItem["o_id"];
          broadCastMe = new broadcastNow(comments.selectedItem["o_id"]);
          for (var i:int = 0; i < comments.selectedItem["o_id"].length; i++)
           connn[comments.selectedItem["o_id"]].addChild(broadCastMe);
      But to to insert into SpriteVisualElement and that every one of SpriteVisualElement (cams)  goes in the horizontal way.... didn't work
      <s:Panel includeIn="indexObjectState" id="camPanel" width="100%" height="150" title="Live Webcams">
        <s:layout>
                  <s:HorizontalLayout paddingLeft="1" paddingRight="1" paddingTop="1" paddingBottom="1" gap="1" />
              </s:layout>
         <s:Group width="290">
         <s:SpriteVisualElement x="100" id="connn" />
        </s:Group>
      </s:Panel>
      So how could I make this work that all of SpriteVisualElement(cams) goes in horizontal next to each other?
        • 1. Re: SpriteVisualElement in for loop
          David_F57 Level 5
          hi,
          you set the panel layout but add the sprites to the group which has no layout, you should just add the sprites straight to the panel or use a hgroup which fills the panel and not worry about panel layout.
          David.
          1 person found this helpful
          • 2. Re: SpriteVisualElement in for loop
            ok,
            But can you say it in codes, becouse I have all cames maded but not seeing all in spritevisualelement only the last one:
                broadCastMe = new broadcastNow(camId);
                connn.addChild(broadCastMe);
            and
              <s:layout>
                    </s:layout>
              </s:Group>
            </s:Panel>
            every time someone clicks on start webcam it fires the function  broadCastMeNow.
            but each time it is other value of camId.
            so how could I add it to the panel with  <s:SpriteVisualElement x="100" id="connn" /> next to each other?
            I suppose I need to do something with connn but what?
