6 Replies Latest reply on Dec 8, 2010 11:59 PM by Albert Widjaja
    SharePoint Connector for WSS or only MOSS?
    Sam Juvonen
      Which version(s) of SharePoint are supported for the LC ES2 SharePoint Connector (WSS / MOSS) ?
      I tried installing on WSS, everything went smoothly until I try to access the Site Settings tools (LiveCycle Settings, Logging Settings), the result was an error:
      File Not Found.   at LiveCycleInterop.Utils.getArrayContentsAsString(String[] stringArray)
         at LiveCycleInterop.Utils..cctor()
        • 1. Re: SharePoint Connector for WSS or only MOSS?
          Raghu A
          MOSS 2007 comes under the supported version.
          Looking at the exception it indicates that there was some problem installing sharepoint connector webpart i.e. running the batch file on your sharepoint server. There are two dlls AdobeLiveCycleConnector.dll and AdobeLiveCycleWorkflow.dll that come with Adobe LiveCycle Connector.zip.
          Please make sure that you have appropriately modified the path
          @SET GACUTILEXE="C:\Program Files\Microsoft SDKs\Windows\v6.0A\bin\gacutil.exe"
          to match the location where gacutil.exe on your machine is placed. Gacutil places these dlls to GAC C:\Windows\assembly folder.
          • 2. Re: SharePoint Connector for WSS or only MOSS?
            Sam Juvonen Level 1
            To confirm, the LC SP Connector will NOT work with WSS ?
            Info from my attempt with WSS:
            The 2 Adobe LiveCycle DLL files are present in the C:\windows\assembly folder.
            The install.bat was modified:
            @SET GACUTILEXE="C:\Program Files\Microsoft SDKs\Windows\v6.1\bin\gacutil.exe"
            @SET TEMPLATEDIR="C:\Program Files\Common Files\Microsoft Shared\web server extensions\12\TEMPLATE"
            @SET RESOURCESDIR="C:\Program Files\Common Files\Microsoft Shared\web server extensions\12\Resources"
            @SET WEBAPPDIR="C:\Inetpub\wwwroot\wss\VirtualDirectories\80"
            @SET SITEURL="http://nortwssdev:80/sites/appdev/"
            @SET STSADM="C:\Program Files\Common Files\Microsoft Shared\web server extensions\12\bin\stsadm.exe"
            The install.bat ran successfully:
            C:\Temp\Adobe LiveCycle Connector>install.bat
            Assembly successfully added to the cache
            Deactivating LiveCycle Connector feature with WSS
            Failed to find the XML file at location '12\Template\Features\LiveCycle\feature.xml'
            Deactivating LiveCycle Workflow feature with WSS
            Failed to find the XML file at location '12\Template\Features\LiveCycle/Workflow\feature.xml'
            Uninstalling LiveCycle Connector with WSS
            Uninstalling LiveCycle Workflow with WSS
            Copying source files to WSS \TEMPLATE directory
            TEMPLATE\FEATURES\LiveCycle\Elements.xml
            TEMPLATE\FEATURES\LiveCycle\Feature.xml
            TEMPLATE\FEATURES\LiveCycle\LiveCycleTasks\AllItems.aspx
            TEMPLATE\FEATURES\LiveCycle\LiveCycleTasks\DispForm.aspx
            TEMPLATE\FEATURES\LiveCycle\LiveCycleTasks\EditForm.aspx
            TEMPLATE\FEATURES\LiveCycle\LiveCycleTasks\NewForm.aspx
            TEMPLATE\FEATURES\LiveCycle\LiveCycleTasks\schema.xml
            TEMPLATE\FEATURES\LiveCycle\Workflow\feature.xml
            TEMPLATE\FEATURES\LiveCycle\Workflow\workflow.xml
            TEMPLATE\LAYOUTS\LiveCycle\ApplyPolicy.aspx
            TEMPLATE\LAYOUTS\LiveCycle\ApplyReaderExtensions.aspx
            TEMPLATE\LAYOUTS\LiveCycle\GeneratePDF.aspx
            TEMPLATE\LAYOUTS\LiveCycle\GetTasks.aspx
            TEMPLATE\LAYOUTS\LiveCycle\InvokeGenericProcess.aspx
            TEMPLATE\LAYOUTS\LiveCycle\LiveCycleSettings.aspx
            TEMPLATE\LAYOUTS\LiveCycle\LoggingSettings.aspx
            TEMPLATE\LAYOUTS\LiveCycle\TaskForm.aspx
            TEMPLATE\LAYOUTS\LiveCycle\Workflow\LCWorkflowSettings.aspx
            23 File(s) copied
            Copying Feature Resource files to WSS 12\Resources directory
            Resources\AdobeLiveCycleConnectorCore.resx
            1 File(s) copied
            Copying Resource files to "C:\Inetpub\wwwroot\wss\VirtualDirectories\80"\App_GlobalResources directory
            App_GlobalResources\AdobeLiveCycleConnector.resx
            App_GlobalResources\AdobeLiveCycleWorkflow.resx
            2 File(s) copied
            Installing LiveCycle Connector with WSS
            Operation completed successfully.
            Installing LiveCycle Workflow with WSS
            Activating LiveCycle Connector with WSS
            Activating LiveCycle Workflow with WSS
            Restarting IIS worker process
            Attempting stop...
            Internet services successfully stopped
            Attempting start...
            Internet services successfully restarted
            • 3. Re: SharePoint Connector for WSS or only MOSS?
              Raghu A Level 1
              Hi Sam,
              I am not very sure if WSS comes under the supported list. I will need to come back on this after some confirmation though.
              • 4. Re: SharePoint Connector for WSS or only MOSS?
                Raghu A Level 1
                Hi Sam,
                Just to make it explicit, WSS does not comes under the supported list.
                Raghu
                • 5. Re: SharePoint Connector for WSS or only MOSS?
                  http://cf.etisbew.com/ Level 1
                  You have raised the perfect question exactly what i am also looking for while for SharePoint Implementation Service from SharePoint Consultants
                  • 6. Re: SharePoint Connector for WSS or only MOSS?
                    Albert Widjaja Level 1
                    OK,
                    does this means that if we want to collaborate the LCES with Sharepoint, the LCES 2.5 must be installed on Windows Server ?
