Command Line build - no images for hardcopy output
Guest
Apr 02, 2010 Apr 02, 2010
I'm using RH8 HTML 8.0.1. In RH, I have no issues with images appearing in my generated .doc files. Same thing with .chms. No issues with images generated via RH or via command line. It's when we try to generate hardcopy output via command line on the server that I am missing all my images. My boss had me perform the following test:
1. On C:\ drive, create a small help project that mimics the folder structure on the network and build server:
C:\html\apps\projects\ct (fct32.xpj resides at the root of "ct" and then I have a "src" subfolder and additional subfolders under "src" that hold the images and html files.
2. Create cmd_RH.bat at the root of C:\
3. Add the following to the batch file:
"C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML\rhcl.exe" "<path><test_project_name>.xpj" -l "<name of the SSL>" -o “<output directory>” -g “c:\temp\RH_test.log”
Actual: "C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML\rhcl.exe" "C:\html\apps\projects\ct\fct32.xpj" -l "Control Reference Guide" -o "c:\temp" -g "c:\temp\RH_test.log"
4. Check for missing images
I have no images in my .doc generated from the batch file. Boss wants me to use an Adobe Lifeline (one of our incidents) but I haven't had much luck in the past with the help desk.
627
Adobe Employee ,
Apr 22, 2010 Apr 22, 2010
Hello,
You need to keep the output directory same as .xpj file location. In order to separate the results, you can create another directory called "output" inside the project folder where the actual .xpj file located.
So the script would be as follow:
"C:\Program Files\Adobe\Adobe  RoboHelp 8\RoboHTML\rhcl.exe"  "<path><test_project_name>.xpj" -l "<name of the SSL>"  -o “C:\Program Files\Adobe\Adobe  RoboHelp 8\RoboHTML\output” -g “c:\temp\RH_test.log”
You can use this, it should resolve the issue.
Adobe Support
Never generate to the same folder as the XPJ file. A sub-folder within the !SSL! folder, which is itself a sub-folder to the project folder with the XPJ file in it, is OK.
I think that is what Robo Cap meant but I wanted to clarify that.
ROBO CAP
You have indicated that you are Adobe Support. Do you mean you are an employee of Adobe or just someone providing a bit of support and adding that as a bit of fun? If the latter, please don't as it is misleading.
@petergrainge
Adobe Employee ,
Apr 23, 2010 Apr 23, 2010
Hello Peter,
No, I didn't mean that, because when we are generating the help file from SSL window in RoboHelp application, it creates the SSL! and other chain of subfolders.
So it can messed up the output generated from command line if we will keep the SSL location. But since it generates many other files while generating help file, so I suggested to create an output directory, so users can create directory with any name just to keep helpfiles separate.
Users should create another subfolder inside output folder if they are generating multiple help file using command line.
I hope this makes sense.
Yes I am an adobe Employee.
I sort of thought we were at one but just wanted to remove that element of doubt.
Good to see support looking in here. I'm sure you understand why I asked.
@petergrainge
RoboHelp Documentation
Download Adobe RoboHelp
