Hey. it's me again with another questiom!!
Yesterday i was finishing a webshop i'm building with Flex 4 and i needed to call a bank page to make the payment. For that i hade to send some values which i thought it could be possible with URLVariables. Well, i can't say that's not possible but when i have to use variables with the "_" character that's where everything gets more complicated cause Flex sends it like some weird characters "%2%" (something like this.
Then i want to te documentaation and thought i've found the solution isind the decode, but it stills sending the variable as "%2%" instead of the "_".
Now, even if you found a way to send the variabe value correctly "word1_word2", how are we going to past the VARIABLE NAME with the same character???
Example:
public function URLVariablesExample() {
var url:String = "http://www.[yourDomain].com/application.jsp";
var request:URLRequest = new URLRequest(url);
var variables:URLVariables = new URLVariables();
variables.exampleSessionId = new Date().getTime();
variables.exampleUserLabel = "guest";
request.data = variables;
navigateToURL(request);
Everything works fine with this example above, but if you need to use a variable (bank api request - nothing i can do to change it) that is for exampe "example_sessionId"?
Hope you understand my question and br able to tell me what to do to make it work!
Thanks!!
LP
How about this:
variables.
example_sessionId= "some_string";
If that's not the answer refrase your question.
