8 Replies Latest reply: Jul 5, 2006 5:25 PM by heathrowe RSS
    Gallery Question
    heathrowe CommunityMVP
      Pretty much understand the gist of the gallery and have a demo setup here.
      And instead of the thumbnails I used the id number inot a css block. I am also aware that id/row count array starts at 0, is there a way to SHOW initial count at 1 instead of zero.
      I know a quick solution is to add another node to my xml files with the literal number and and display that node, but was wondering if the array count can be rigged.
      h
        • 1. Re: Gallery Question
          Donald Booth Community Member
          Sure.
          Under your data set declaration, add:
          dsPhotos.setCurrentRow('1');
          or whatever you want the default row to be...
          Hope this helps.
          Don
          • 2. Re: Gallery Question
            Hi Donald, thanks for the heads up.
            I saw that use in the examples, but they all used in conjunction with a onChange event.
            Since I want to load the array onloading (automatically) and not have to be triggered/fired off by an event, what notation do I use in your example to get it to work?
            • 3. Re: Gallery Question
              Can you verify that I have the dsPhotos.setCurrentRow('1'); in the correct location?
              I tried placing it in various locations, but it still dosn't change the default array initial count from 0 to 1.
              Gallery Here
              • 4. Re: Gallery Question
                Anyone know how to implement donalds suggestion?
                Still can't figure out setting the array to 0 onpage load.
                h
                • 5. Re: Gallery Question
                  Newsgroup_User Community Member
                  Reading some threads on this forum, I found this fix for starting the
                  numbering at 1 posted by ::Andy. (Seems it's not possible to do as of
                  yet without editing SpryData.js, though I'm sure it's coming in the future.)
                  ds_RowNumber starting at zero
                  Added {ds_RowCounter} in sprydata.js to get round the problem of
                  displaying 0
                  when listing items. I have tried not to modified the
                  sprydata.js as I don't want to be in position as not to easily
                  upgrade. But I
                  could'nt find anyway around this with something
                  like {ds_RowNumber+1} for example.
                  Line 2098 sprydata.js -
                  if (token.data == "ds_RowNumber")
                  outputStr += dsContext.getRowIndex();
                  else if (token.data == "ds_RowCount")
                  outputStr += dsContext.getNumRows();
                  else if (token.data == "ds_RowCounter")
                  outputStr += dsContext.getRowIndex()+1;
                  else
                  var curDataSetRow = dsContext.getCurrentRow();
                  if (curDataSetRow)
                  outputStr += curDataSetRow[token.data];
                  > h
                  • 6. Re: Gallery Question
                    thanks imagic for finding that for me, though that particular area is in adifferent location in the latest build of that file, with it implemented it still didn't bring change.
                    But thanks for pointing me in the direction - I may have to play with some lines here to try and figure it out.
                    h
                    • 7. Re: Gallery Question
                      kinblas Community Member
                      Hi heathrowe,
                      Did you change your HTML code to use {ds_RowCounter} after you made that JS change?
                      Are you using {ds_RowCounter} in a spry:if or spry:test attribute? Or in HTML content?
                      --== Kin ==--
                      • 8. Gallery Question
                        Ah - thanks Kin, that was the direction I needed.
                        I neglected to change the ds_rowid to ds_RowCounter, as originally suggested.
                        It introduces new issues to my scheme, but thats ok for now - glad to get that sorted out.
                        h
