Hi all,
Some of the shortcuts are not working in Windows 7.
E.G. Ctrl + Space does nothing.
Anyone have a solution?
Do you have an example of when it doesn't work? Or does it not work at all? There are cases when we expect no code hints. There are also cases where nothing appears do to missing SWCs on the library path.
Jason San Jose
Software Engineer, Flash Builder
Hi Jason,
Here is an example:
Window > Preferences > General > Keys
If I select the command "Content Assist" in the list, the Binding is Ctrl+Space.
This shortcut/binding does not work in the editor, and if I remove that binding and try and set it again by pressing Ctrl+Space, the binding does not appear in the binding field.
If I press Shift+Space, that works, and I can use that binding ok for Content Assist.
What operating system and language are you using? Could be a keyboard or language specific issue.
Jason San Jose
I am using Windows 7 Home Premium 32bit.
English (Aus).
Hilary
