Hi there,
I have installed a LiveCycle ES2 and a LiveCyle Workbenche ES on one windows server 2008 "A" and a LiveCycle Workbenche ES on another windows server 2008 "B" as well. Both of them are in our company domaem. But when I want to login in with Workbenche ES from server "B" to CliveCycle on server "A". I get failure message, that I should check the netzwerk connetion setting.
I have ever shout down firewall, and checked the DNS-ip. I can use the same user data to login with the workbenche on server "A", it means, the user data was right. I have run the workbenche as administrator.
Where I could still check. What could be the reason. Could sombady help?! thanks very much!!
Best regards
Lisa
Solved! Go to Solution.
Total Likes
That's what I was afraid of.
I ran into a similar problem trying to access adminui on a Windows 2008 server and that's because Win 2008 server block a bunch of ports.
I had to run a script I found somewhere on the web to open the ports.
You probably don't need to open them all up. I added 8080 and 8443 in the script and just ran it in a Command window and that fixed my problem.
Here's the script:
@echo ========= SQL Server Ports ===================
@echo Enabling SQLServer default instance port 1433
netsh firewall set portopening TCP 1433 "SQLServer"
@echo Enabling Dedicated Admin Connection port 1434
netsh firewall set portopening TCP 1434 "SQL Admin Connection"
@echo Enabling conventional SQL Server Service Broker port 4022
netsh firewall set portopening TCP 4022 "SQL Service Broker"
@echo Enabling Transact-SQL Debugger/RPC port 135
netsh firewall set portopening TCP 135 "SQL Debugger/RPC"
@echo ========= Analysis Services Ports ==============
@echo Enabling SSAS Default Instance port 2383
netsh firewall set portopening TCP 2383 "Analysis Services"
@echo Enabling SQL Server Browser Service port 2382
netsh firewall set portopening TCP 2382 "SQL Browser"
@echo ========= Misc Applications ==============
@echo Enabling HTTP port 80
netsh firewall set portopening TCP 80 "HTTP"
@echo Enabling HTTP port 8080
netsh firewall set portopening TCP 8080 "JBoss"
@echo Enabling SSL port 443
netsh firewall set portopening TCP 443 "SSL"
@echo Enabling SSL port 8443
netsh firewall set portopening TCP 8443 "JBoss SSL"
@echo Enabling port for SQL Server Browser Service's 'Browse' Button
netsh firewall set portopening UDP 1434 "SQL Browser"
@echo Allowing multicast broadcast response on UDP (Browser Service Enumerations OK)
netsh firewall set multicastbroadcastresponse ENABLE
Jasmin
Total Likes
What are you setting you connection to?
Try to use the IP address of server A in your connection settings.
Jasmin
Total Likes
Hi Jasmin,
thanks for this answer. But it is not clear enough for me. Which connection setting did you mean? Is that on the login screen, where I can manage configured servers? If that is what you meant, I set already the IP address of the server A. Or maybe you mean somewhere else?
Best regards
Lisa
Total Likes
Yes. I meant the connection from the login page.
What operating system are you using on server A?
Jasmin
Total Likes
The OS on the server A is Windows Server 2008 R2 and the OS on the server B is Windows Server 2008.
Lisa
Total Likes
Here's the script:
Jasmin
Total Likes
Hi Jasmin,
thanks very much!! I have tried the script and it works.
Best regards
Lisa
Total Likes
