Hi all,
How can you customize bullets so that:
- The circle bullet's radius is a bit smaller
- The indentation is a bit less
(Maybe this is more CSS than RH.)
TIA
- avraham
It is indeed a css question. To get this to work correctly (and keep it working correctly if you upgrade to a new RH version) there are several steps you have to take. What you need to do depends on what you want. Do you use only one kind of unordered list?
If you use only one kind, the easiest way goes like this:
1. In your CSS add UL {font-size: 10pt;}. Amend the value to make the bullet larger/smaller.
2. Next, set the indent in the added UL tag. Add margin-left: xxpt; Amend the value to make it indent more or less.
3. In RoboHelp, create a new paragraph. Give this paragraph the styling you want, including font size. Do not add a bullet!
4. In RH, click the unordered list button. Then select the paragraph you created.
Greet,
Willam
This e-mail is personal. For our full disclaimer, please visit www.centric.eu/disclaimer.
1. Wow! Thanks!
2. "Do you use only one kind of unordered list?"
No. Where necessary, I need a Level 1 bulleted list and also a Level 2
bulleted list.
3. I also have to generate Word/PDF. Have you by any chance got any idea how
well the mechanism you presented (are presenting) works with conversion to
Word/PDF?
Great thanks,
- avi
