I'm having trouble finding the right properties for removing a gradient for a spark TabBar.
Is there a way to do that with css or will I need to create a custom skin to do the job?
Thanks.
For a full example, see http://blog.flexexamples.com/2010/05/04/setting-a-solid-tab-fill-on-a-spark-tabbar-control-in-flex-4/
Peter
hi,
I think the customised skin is the way to go, then again anything that lets me escape css is the better alternative
David.
Thanks. I does look like skins will give you much greater control over the look of the application.
I suppose I could use the <s:LinearGradient> tag with the same two colors within the <s:GradientEntry> tag. Surely there's a property to just set the component to a solid color.
-David
hi,
you can get quite fancy with skins for instance you can have some code that would add either gradient fills or solid fills depending on a variable set in the application(the lazy way when you don't want to extend the component).
Its way past sleep time at the moment so I will slap something together in the morning to give you an idea of the 'quikfix' methodology
David
Still looking for a solution.
I've tried just using SolidColor in various skin classes and nothing seems to be working.
Any ideas?
I created a custom Spark TabBar skin, and set a custom TabBarButton skin with the following fill:
<!--- layer 2: fill -->
<s:Rect id="fill" left="1" right="1" top="1" bottom="1" topLeftRadiusX="4" topRightRadiusX="4" width="69" height="21">
<s:fill>
<s:SolidColor color="0xFF0000"
color.selectedUpStates="0xBBBDBD"
color.overStates="0xBBBDBD"
color.downStates="0xAAAAAA"
alpha="0.85"
alpha.overAndSelected="1" />
</s:fill>
</s:Rect>
Peter
For a full example, see http://blog.flexexamples.com/2010/05/04/setting-a-solid-tab-fill-on-a-spark-tabbar-control-in-flex-4...
Peter
Ah ha! The button skin. I forgot about that.
Thank you very much!
